Anyone add the Canadian fogs to the US version?
ivancook
Ivan
2024 Civic Si
Has anyone been able to find a plug and play solution using OEM parts that functions just like the other US spec cars that come stock with fog lights? I've seen the Mikstore stuff, but that requires splicing and has the wrong stalk, right?
Dtec0804
David
southington CT
2024 honda civic si
I just installed these a couple days ago. Works great. I skipped installing the switch and left the lights on Auto.
Hey man which ones from that site did you buy and did it come with the switch??
I attempted find Honda OEM fog lights for the FL5, no such part number seems to be available, neither US, Canada, nor JDM, Europe, etc.
Based on research, the Spyder fog lights seem easiest to install ("direct bolt-on"), include harness and switch.
https://shop.spyderauto.com/products/9051203
But are they any good?
Bright (no lumen output listed, only 5W LED), good throw/pattern?
Reliable?
Indeed easy to install (no installation instructions on t eh spyder auto website...)
The same research indicates that Mikstore or SWA fog lights require trimming of the FL5 bezel, which I rather not do.
I asked Diode Dynamics for recommendation:
I myself had a '22 Sport Sedan (Not nearly the same in terms of performance, but identical for the front crash bar!) and mounted some of our SS6 lightbars directly to the bottom of the crash bar. (The front crash bar has a thin sort of 'shelf' along the back edge that you can drill right through, and mount lights directly to!) I also did this same install on a '25 Sport Sedan, and it worked the same way:
11th Gen Honda Civic Anyone add the Canadian fogs to the US version? Diode Dynamics on 2025 Civic Sport
For that install, I used the lights we offer, plus their standard harness, and this Honda-style switch from Amazon​
