Backup Camera Glare
Anyone have issues with glare with the backup camera at night? coming from a 2021 tacoma, the civic is much harder to see when reversing. I think the LED license plate bulb is too bright causing a glare. Any solutions to this?
MERAKIAUTOWORKS
Joshua
Fullerton, CA
2022 Civic Type R
Sorry a little off topic but is there a way for the camera to stay on for a little after leaving reverse?
-Josh
ayospoonay
Josh
Orlando
2022 PWP Si
-Josh
Don't think these cars can be coded like VWs for that to happen. Once you're out of reverse gear the camera goes out.
looks like rockauto sells regular halogen bulbs that fit. Philips 921. i think the LED is too bright. i also read LED bulbs can cause some electrical interference leading to a fuzzy image with backup camera. the bulbs are $0.35 each so i'll just try to find one at the store so i don't have to pay shipping.
I recently had some glare on my rear view camera, but turned out the camera lens was dirty. Cleaned it with a microfiber cloth and everything is fine now.
I haven't found the license plate LED to be too bright when in reverse, but I also installed very bright LED reverse lights that seem to slightly improve the poor image from the rear camera.
i'll try cleaning the lens again. might add a ceramic coating to it to help water bead off.
Shankmeyster
AZ
23 Type R
If your backup camera is messed up, take it in to the dealer and they will most likely replace it under warranty. I had my backup camera replaced already for blurry output and this isn't the first recent Civic that I had to have it done on.
it's brand new. just got it a couple weeks ago and noticed this the first time i used it at nighttime. i was hoping there was some piece of plastic still left on the camera to protect it during shipping but nothing that I could see. Looks fine in the daylight.
Shankmeyster
AZ
23 Type R
The question is how long did it sit on the lot before you got it? If it was a while then water spots could have burnt into the lens.
it was built in August 2023 and i bought it in October. The dealership kept their Si's on the showroom floor so it wasn't even stored outdoors.
