BuntaTypeR
I'm a seasoned car enthusiast still enjoying my passion. Even though car modifications aren't new to me, I want to share some pictures of my Type R build. I'll be posting all my photos and video links here from now on."
2024 Honda Civic Type R transformation:
Future Plan:
  1. OS Giken SuperLock LSD
  2. OS Giken HTR Twin Disc Clutch Kit
  3. 4 Piston Racing Oil Pan Baffle
  4. S.E.S 3-4 Gear upgrade 1000HP Synchromesh
  5. Spoon USA Thermostat
  6. Racebreed Front Splitter
Modifications list:
Engine/Power:
JSR Engines tuned e85 - 5 maps
MHI Stage 2 OEM Turbo Upgrade
Hondata flex fuel kit
Hondata 1530cc Injectors
Full Race high pressure fuel pump kit
DeatschWerks 340lph DW300C Compact Fuel Pump
NGK Ruthenium HX Spark Plug
AEM 340 low-pressure fuel pump (was not installed, as my tuner advised against using it.)
Hondata flashpro mini
PRL intercooler
TSP downpipe
JSR Burnt Titanium Down Pipe Hardware Kit
TSP x PTP Turbo blanket
PRL HVI intake
PRL Titanium Turbocharger Inlet Pipe Kit
Cooling:
PRL front pipe with heat wrap
Lava Downpipe blanket
27won air intake snorkel
Acuity Super Cooler Reverse Flow Silicone Radiator Hose
WOT Performance PWR Triple Pass Radiator + Trans Cooler
DUAL = G-Plus 25 Row AN10 10AN Oil Cooler Kit
Mishimoto aluminum expansion tank
PLM Vented Engine Splash Guard Plate
Suspension:
JRZ RS PRO with Stäubli Quick Disconnects
Eibach lowering springs -0.5 inch drop. Spring rates - 12kg Front and 22kg rear.
Tein Error Canceller Kit
Spoon rigid collar front and rear
Spoon Stiff Plate Front
RV6 Adjustable Chromoly Rear Sway Bar Kit
Cusco Front Strut Tower Brace
PRL Rear mount engine mount
Eibach -Rear Camber Pro Alignment Kit
Drivetrain:
Hybrid racing short shifter assembly
Hybrid racing heavy duty trans detent springs
Technafit stainless steel clutch line
Interior:
Hybrid Racing Titanium Competition Shift Rod
Chasing Js - Titanium Shift Boot Delete
Recardo Pole Position - Jersey Red
Bride Zeta IV Carbon Fiber
Bride rail seats
Schroth 4 point harness - quickfit
Exterior:
CF hood with vents
CF Spoon Crane Neck Wing
CF fender with vents
Wheels and tires:
Apex VS-5RS 18x9.5" ET45 Wheel - 5x120mm / 64.1mm - Motorsport Gold
Bridgestone Potenza RE 71RS - 265/35
Evasive Titanium lug nuts
ARP wheel stud
Mishimoto hub centric wheel spacer 10mm
Brakes:
AP Racing by Essex Radi-CAL Competition Brake Kit (Front CP9668/372mm) with Pad Tension Kit
Front Brake pads - FERODO DS1.11
Paragon rear rotors - slotted
Paragon brake pads - rear R3
Paragon titanium brakepad shims
Goodridge G-Stop SS Brake Line Kit
Wunderladen Racing Rear brake caliper bushings
Castrol React SRF Synthetic Racing Brake Fluid
Misc:
Spoon radiator cap
Spoon oil filler cap
Spoon shift knob
Day 1 at the dealership:
11th Gen Honda Civic BuntaTypeR Boost Blue Build 417384672_10231355211333175_7240024873256334634_n
11th Gen Honda Civic BuntaTypeR Boost Blue Build 417433991_10231443963951935_5084402624368485539_n
11th Gen Honda Civic BuntaTypeR Boost Blue Build 417438182_10231594100825263_8768365376040361138_n
11th Gen Honda Civic BuntaTypeR Boost Blue Build 418170720_10231594103665334_8442878620448293589_n
11th Gen Honda Civic BuntaTypeR Boost Blue Build 448867272_10232269224222926_7731356954723009057_n
11th Gen Honda Civic BuntaTypeR Boost Blue Build 448929559_10232273219282800_8065921723012247684_n
11th Gen Honda Civic BuntaTypeR Boost Blue Build 448929952_10232269221622861_8474345388329636146_n
11th Gen Honda Civic BuntaTypeR Boost Blue Build 448934109_10232269224982945_4463958011102945912_n
11th Gen Honda Civic BuntaTypeR Boost Blue Build 452281516_10232485641753229_2684020203412817627_n
11th Gen Honda Civic BuntaTypeR Boost Blue Build 454637267_10232710806702212_8939509320874880022_n
11th Gen Honda Civic BuntaTypeR Boost Blue Build 454755686_10232710805222175_5552512003597779890_n
11th Gen Honda Civic BuntaTypeR Boost Blue Build 456381463_10232869795076822_4907916319035928064_n
11th Gen Honda Civic BuntaTypeR Boost Blue Build 456485647_10232869794356804_6969037506181828816_n
11th Gen Honda Civic BuntaTypeR Boost Blue Build 456759601_10232869793636786_1824451299406764122_n
11th Gen Honda Civic BuntaTypeR Boost Blue Build 1000069431
11th Gen Honda Civic BuntaTypeR Boost Blue Build 1000069400
11th Gen Honda Civic BuntaTypeR Boost Blue Build 1000069402
11th Gen Honda Civic BuntaTypeR Boost Blue Build 1000069404
11th Gen Honda Civic BuntaTypeR Boost Blue Build 1000069406
11th Gen Honda Civic BuntaTypeR Boost Blue Build 1000069408
11th Gen Honda Civic BuntaTypeR Boost Blue Build 1000069410
11th Gen Honda Civic BuntaTypeR Boost Blue Build 1000069412
More to come...
11th Gen Honda Civic BuntaTypeR Boost Blue Build 1000069398
11th Gen Honda Civic BuntaTypeR Boost Blue Build 1725153574998-ia
11th Gen Honda Civic BuntaTypeR Boost Blue Build 1725153594812-z
old stock:
11th Gen Honda Civic BuntaTypeR Boost Blue Build 1725153637202-oc
ItsMeNickG
Nick
2023 Honda Civic Type-R
A tasteful set of modifications, looks good! I have the same reverse flow hoses ready to be installed.
ItsMeNickG
Nick
Are those the CMST fenders?
Nice CRX!
BuntaTypeR
BuntaTypeR
Nice CRX!
fenders are from alibaba. it is cheaper!
That’s my brother-in-law’s CRX with a turbocharged B20 engine, and it’s insanely fast on the track with an unbeatable power-to-weight ratio. Sometimes I wonder if I should get the same car to reduce my consumable costs.
Get a used Miata. Cheap consumables and fun to drive (also the butt of jokes at every track day drivers meeting).
BuntaTypeR
BuntaTypeR
After totaling my S2000, I vowed never to buy another RWD car. From now on, I'll stick with FWD and AWD. Even though my Tesla is AWD, it’s RWD-biased. Roadsters are great until you try to use them for dual purposes. The main reason I bought the Type R is to track it while still being able to take 2-5 hour trips on holidays or weekends. My 2nd choice was the brand M2 and the Supra.
Maybe in the future, I’ll get a CRX. My brother-in-law has two, so I’m sure I can convince him to sell me the second one with a B18 in it.
11th Gen Honda Civic BuntaTypeR Boost Blue Build 1725210156713-0x
11th Gen Honda Civic BuntaTypeR Boost Blue Build 1725210198149-b3
I hear you. I retired my S2000 to C&C and to the dentist duties. I’m using the FL5 for track days because it takes a lot to trash a FWD car. But my comment was based on your comment about cheap consumables. A used Miata is cheaper to start with and you would get the same “momentum” driving as the CRX.
svvitch
Just looking at those Bride seats makes me feel fat ? Great build thread!
BuntaTypeR
BuntaTypeR
Went to Streets of Willow yesterday, where the highest temp reached 102°F. Thankfully, I didn’t notice any signs of overheating from the car. However, I keep an eye on the temps and slow down once it exceeds 250°F. I feel a noticeable loss in power between 220°F and 240°F. The vents seem to have made a big difference compared to my last visit, where I was overheating by the second or third lap. This time, I managed to run 7-8 laps. Around the 5th lap, though, my tires felt shot, and I was sliding quite a bit. The RV6 rear sway bar and Spoon front stiff plate seem to help a lot—I can brake late and swing the car confidently. Surprisingly, the rear isn’t oversteering, just enough slide to assist my novice skills. I’ll be installing a second oil cooler soon, hopefully by next weekend. Here are some pics:
