albi
albi
Dallas, TX
That first shot lives in my head rent free lol
Preciate it bro! ❤ We did more rollers, but that one was my favorite by far
NERO808
‘20 SGP Type R • ‘23 CW Type R
Everybody needs a "go to" picture or video for their spank bank - we won't judge.
LMAO! I owned a white ‘17 Civic Hatch Sport and this was my ratatouille moment that made me realize CW was what I really wanted lol
albi
albi
Dallas, TX
Been slacking on the updates. Have more sitting in the office floor but it is too hot in Texas to do anything else until the Fall.
Beatrush rear strut bar: you will have to cut into the liner, but it is much less noticeable than other rear strut bars available. Literally, two small slits with the razor blade and push the bracket through. Watch out for the hatchback side trim clips, they are incredibly easy to break (just like many other clips on the car).
11th Gen Honda Civic Championship White FL5 #943 Build Screenshot_20230706_215720_Gallery
11th Gen Honda Civic Championship White FL5 #943 Build Screenshot_20230706_215724_Gallery
Magic Collar rigid collars: signifcantly reduces the bounciness and keeps the body planted. Does take some time for install (~4 hours) and if you don't have access to a lift probably worth having someone else do it.
11th Gen Honda Civic Championship White FL5 #943 Build PSX_20230621_134305
Flap Fab stone guards: pinpoint precision fitment and good quality. Much better than the DIY set I had prior and shout out to @TR3BLE for the YT video introducing me to this company. :thumbsup:
11th Gen Honda Civic Championship White FL5 #943 Build 20230711_121854
11th Gen Honda Civic Championship White FL5 #943 Build 20230711_124610
11th Gen Honda Civic Championship White FL5 #943 Build 20230711_124709
@Suma Performance rear and side view mirrors: these are a game changer. I can see a minimum of 3 lanes of traffic on each side, absolutely no blind spots while retaining the BSI and heated functionality. The 10th gen Type R has the same rear view mirror model as the 11th gen, so you can order the 10th gen from their website and it will fit seamlessly.
11th Gen Honda Civic Championship White FL5 #943 Build Screenshot_20230607_210941_Gallery
11th Gen Honda Civic Championship White FL5 #943 Build Screenshot_20230607_210957_Gallery
@TypeRLEDs turn signals and reverse lights: always hated the amber bulbs, and I wanted to support a Type R focused company more than Lasfit ?‍♂. Be aware, they are BRIGHT. (Reverse lights not shown since main focus was getting rid of the amber and only got the reverse so they would match).
Before -
11th Gen Honda Civic Championship White FL5 #943 Build 20230621_195900
After -
11th Gen Honda Civic Championship White FL5 #943 Build 20230621_201758
Jets Vinyl headlight tint: shout out to @arbies for putting me on to this company. Amber lights are the worst and this is the next best thing to the JDM headlight. Dry vinyl installation that takes like 10-20 minutes.
Before -
11th Gen Honda Civic Championship White FL5 #943 Build 20230628_140142
After -
11th Gen Honda Civic Championship White FL5 #943 Build 20230628_144408
Rywire ground kit: all the OEM grounds are not good. Rywire makes a universal kit that has all the ground wires you need and remedies that. The quality comparison is night and day and there is no longer exposure on the ends, and rather heat shrinked the way it should be.
11th Gen Honda Civic Championship White FL5 #943 Build 20230516_125049
Miscellanous: PRL rear motor mount, braided clutch line, Dream Automotive braided brake lines, and Acuity shifter cable bushings. RMM is the big ticket and assists in reducing wheel hop dramatically.
11th Gen Honda Civic Championship White FL5 #943 Build 20230711_163555 (1)
TypeRLEDs
#1 Source for 10thgen LEDs
Houston TX
TypeRLEDs.com
2017 Honda Civic Type R
Been slacking on the updates, so here is a dump. Have more sitting in the office floor but it is too hot in Texas to do anything else until the Fall.
Before -
After -
Before -
After -
Thank you so much for the support! Looks great!
albi
albi
Dallas, TX
APR radiator cooling plate, need the side shroud plates now. They have estimated production for those will be done mid-late July.
11th Gen Honda Civic Championship White FL5 #943 Build 20230713_161226
11th Gen Honda Civic Championship White FL5 #943 Build 20230713_161233
11th Gen Honda Civic Championship White FL5 #943 Build 20230713_161347
Garage Unique front lip secured, need to ceramic coat and will install after.
11th Gen Honda Civic Championship White FL5 #943 Build 20230713_150230
albi
albi
Dallas, TX
SKINNIE
DFW TX
ISF, 23' BB FL5
Great suggestion! I am planning on swapping these guys out when I do a short shifter swap. Still deciding if I want to go with Hybrid or Acuity... There are some pros and cons for each. Too many things to do and too little money ? hahaha
I did the shifter base bushings, cable bushings and the detent springs. It made the shifter even more crisper.
They way you're putting mods into it. Looks like money isn't a problem ?
albi
albi
Dallas, TX
? certainly financially irresponsible without question, but at least it's an investment into something I can use on a daily basis and enjoy regularly
albi
albi
Dallas, TX
Where did you get the CF radiator cooling plate??
APR Performance. Carbon side shroud cooling plates should be coming end of this month (at least what they are expecting)
albi
albi
Dallas, TX
Garage Unique carbon front lip: couldn't be happier, the best FL5 front lip imho. Has that OEM+ look with more aggressiveness. Tried to get different angles in case somebody may be interested and wasn't quite sure. If you have a specific question or want a particular shot, let me know and I can get it for you no problem.
11th Gen Honda Civic Championship White FL5 #943 Build 20230718_194806
11th Gen Honda Civic Championship White FL5 #943 Build 20230718_194656
11th Gen Honda Civic Championship White FL5 #943 Build 20230718_195043
11th Gen Honda Civic Championship White FL5 #943 Build 20230718_194502
11th Gen Honda Civic Championship White FL5 #943 Build 20230718_194933
11th Gen Honda Civic Championship White FL5 #943 Build 20230718_194551
11th Gen Honda Civic Championship White FL5 #943 Build 20230718_194950
11th Gen Honda Civic Championship White FL5 #943 Build 20230718_194829
11th Gen Honda Civic Championship White FL5 #943 Build 20230718_194729
11th Gen Honda Civic Championship White FL5 #943 Build 20230718_195055
