Clix Auto Wiperblades... not compatible with 2024 FL5?
a c i d.f l y
Austin
2024 Honda Civic Type R
These looked really cool in photos, which is where things started to go wrong. Silicon, looked decent enough, easy to replace the inserts, hot swappable yadda yadda.
The 10th and 11th gens have drastically different windshields, wipers, and wiper connecting arms. They have two different Type R products listed, one with the FK8, one with the FL5. The one with the FL5 pictured said it was compatible with "2017-2023 Type R"... So I ordered some. 2023 and 2024 should be the same, right?
Well, yes and no.
The blades they sent me are for the 10th gen, so they're too long and too short, and while the connector is compatible with the clip-in style, Honda ****** the connector enough to not be backwards compatible. So, they won't clip in or snap in securely.
Also, the design or color that I chose appears to be holographic or carbon fiber, but it's just a printed image on a rubber cover that actually looks like green and pink basketweaving up close. It looks really cheap, if I'm being honest.
Lastly, and this is product QA, the blades were missing the protective sheath, so the blades themselves are kinked from being pressed in the package.
It's on me for assuming '23 and' 24 compatibility, but then everything else... I'm still waiting to hear back from their customer support. They were pretty immediate when I asked about '24 and '25 compatibility for my wife' s CR-V, but no response on this current issue.
https://clixauto.com/products/honda-civic-type-r-windshield-wiper-blades?variant=40770485682236
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 20240817_102701
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 20240817_102129
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 20240817_102529
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 20240817_102615
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 20240817_102625
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 20240817_110527
menikmati
STI, BRZ, FL5
Well, yes and no.
If it's listed as being compatiable with 2017-2023 model years then it encompasses both the FK8 and FL5 and knowing that the 10th/11th gen wipers are different should've been the first red flag.
Wipers look just as cheap on the website compared to the photos you provided, IMO. This is why I recommend people stick with OEM or well-known name brand wipers (Bosch, Rain-X, PIAA, etc).
The FL5 on the product page is a stock photo, doesn't even have the product they are advertising installed on it...
madbikes
SF Bay Area
Other than the classic style wiper clip, it is the best to buy from dealer if you want to be correct the moment you buy one without a thought.
The site OP got them has the wrong clip
a c i d.f l y
a c i d.f l y
Austin
Normally I'd go with PIAA's SI-TECH, those last freaking forever and have by far the best performance. It's not even close. They're expensive tho, and they don't offer compatibility with these clips yet.
That said, the factory blades are one of the weakest points on the vehicle (next to the low resolution backup camera), so even a basic silicon blade is going to be an improvement. I just know Bosch, Rainx, whatever other option you can get at Autozone is gonna be toast in 3 months in this Texas sun, so was trying to give something new a try. Serves me right, I guess.
menikmati
STI, BRZ, FL5
A set of PIAA Si-Tech (24"/19") is around $60. OEM (76630-T20-A01 and 76620-T60-A01) are about the same price. Unless something has changed, wiper blades come with a variety of adapters and should just slot in or use some J-hook interface. Correct me if I'm wrong.
How did you come to this conclusion? Have you or the weather worn yours out or have they somehow degraded within a year of ownership?
The Clix website is a joke, all of their product descriptions are from a cookie-cutter template:
"Looking for Windshield Wiper Blades guaranteed to fit your [INSERT CAR MODEL HERE]? Look no further! Our premium wiper blades include two correct size blades for the front windshield, providing you with the best performance for the price in the market. Choose from a wide range of styles and colors to match your car's personality. Plus, with our subscription option, you can enjoy the convenience of automatic replacements and Lifetime warranty. Say goodbye to worrying about your wipers ever again! Don't miss out on these top-quality blades designed to keep your windshield clear and your driving experience safe."
If a wiper website doesn't list the measurements for their wipers for the driver and passengers side or have a decent fitment wizard/chart then they're not worth your money.
a c i d.f l y
a c i d.f l y
Austin
Because the factory blades have sucked from day 1.
And PIAA were $60 when normal wipers were still $10-20 per. PIAA were $35+$30 for the ones I got for my 2017. That's what normal blades cost now (a pair of RainX are $30+30, wtf...). I would get maybe 6mo-2years out of any brand/style blade until the PIAA's, which lasted 3-4 years before lines started showing up.
And no, the connectors aren't simple J or C hooks, unfortunately. They're click-in style, and the new Honda click-ins aren't compatible with the previous click-in, either, apparently. PIAA Si-tech doesn't come with either, just all the old styles.
Not sure on their new Aero model. That's next on my list to be tested.
menikmati
STI, BRZ, FL5
Well, how do they suck?
This is the first post I've seen where I've heard someone being dissatisifed with the OEM wipers.
EDIT:
Someone on another 11th gen forum had success with Rain-X.
I'm going to say that the PIAA Si-Tech that I mentioned earlier should come with the appropriate PTB-arm adapter. I also cross-checked with the Amazon listing and saw customer images that also use the PTB-arm style wiper blade.
https://www.tirerack.com/wipers/det...Model=Civic+Type+R&autoYear=2023&autoModClar=
https://www.tirerack.com/images/wipers/piaa/SITech/oecover.pdf
a c i d.f l y
a c i d.f l y
Austin
Generic OE blades are going to perform at an "average" level. My issue is likely more related to the sprayers than the generic blades they come with. The wiper sprayers are supposedly more efficient but also less effective. And a direct compatibility issue with these blades.
They've initiated a refund and sent me a return label.
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 1724080253349-6b
I've ordered a set of PIAA SI-Techs. Hopefully, they will send me the updated package with the PTB attachment that will be compatible with the sprayer arms.
a c i d.f l y
a c i d.f l y
Austin
None of the PIAA adapters work with the stupid wiper arm sprayers!! UGH.
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 20240820_122844
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 20240820_122951
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 20240820_123427
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 20240820_123433
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 20240820_123620
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 20240820_123756
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 20240820_123805
CivicSportSGP
NA
Honda Civic, Mazda CX-5
Sorry for the bump, but I found this video on YouTube that shows that trimming off one of the ears on clip "B" allows the use of the SI Tech.
I haven't tried it personally, but I do want to upgrade to silicone blades. I'm just worried about how PIAAs would sit on the windshield versus OEM.
a c i d.f l y
a c i d.f l y
Austin
Total W my dude. I didn't want to experiment with modifying the clips and have them fly off, but looks like this is a clean mod to get a significantly improved wiper experience!
a c i d.f l y
a c i d.f l y
Austin
One change to this video, this is for a right hand drive vehicle. The wipers are the opposite on left hand drive. I clipped the left side on the first blade and ended up having to clip the right side. It still works, though it has 1mm of play. The passenger window clipping only the right side wing of the attachment sits securely. I'm waiting for the window treatment to dry to wipe it off. It's actually raining today, so I may get to test these out.
Again, for left hand drive (US), clip the right wing. 👉🏼
For right hand drive (JP), clip the left wing. 👈🏼
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 20251121_065008
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 20251121_065818
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 20251121_065052
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 20251121_065351
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 20251121_065814
11th Gen Honda Civic Clix Auto Wiperblades... not compatible with 2024 FL5? 20251121_065342
a c i d.f l y
a c i d.f l y
Austin
An update - the PIAA Si Tech wipers work astonishingly well. I'm no longer constantly annoyed by streaks and smears produced by even brand new OE blades. Extremely recommended!
Blindeye_03
Cincinnati Ohio
'24 CTR - red
I will be buying some aftermarket blades soon - Windshield streaks bother me like none other.. OCD level lol. The OEM blades longevity and performance suck. I liked the bosh blades I had on my fk8.. Anyways..
Has anyone used any bosch blades successfully? If not then PIAA Si Tech it is..
