Codes after stage 2 with pops from phearable
YamenA
Yamen
North Carolina
2024 Honda Civic Type R (FL5)
I recently tuned my FL5 type r i have prl intake and inlet pipe and also a catless donwpipe and got the phearable stage 2 tune with pops and bangs and i recently got a few codes such as p2196, p050a and p0507 im not sure if they came from the tune and how to fix them.
naafl5
Maryland
How long after being on the tune did the codes pop up? The easiest way would be to flash back to stock, drive around a bit and see if the codes come back.
That first code is likely from your downpipe since it's a O2 sensor code (reading too rich likely), second code is "Cold Start Idle Air Control System Performance" issue, meaning the engine's idle control system isn't functioning correctly during cold starts" (copied that from Google), and your last code is "Idle Control System RPM Higher than Expected" and usually means the engine's idle speed is higher than programmed, potentially due to vacuum leaks, a faulty idle air control valve, or other issues".
Sounds to me like the last two codes are tune related, do you know if the phearable tune changes idle rpm?
Deleted member 42584
Probably you mod your intake , will need to do the MAF calibration, or swap to stock.
SKINNIE
DFW TX
ISF, 23' BB FL5
Is your Hondata updated to the latest firmware?
YamenA
YamenA
Yamen
North Carolina
I dont think its from the tune because I emailed phearable and they told me that their tune should not throw any codes and probably an issue with the parts
YamenA
YamenA
Yamen
North Carolina
Some of them came up the same day after a few hours and i recently got a new code as well P0046.
