CW rear bumper color mismatch - So common! Did you ever notice?
flaviodiniz
Flavio
Orlando - FL
So, I never actually saw people discussing it. But did you guys realize how common it is for CW rear bumper color to mismatch the rear side panel (but at the same time match perfectly the trunk lid)?
P.S.: Found all the images on the internet. However, I've done my best so that people can't recognize any of the cars. If someone wants a pic removed, just lmk.
11th Gen Honda Civic CW rear bumper color mismatch - So common! Did you ever notice? 318195108_206211911800993_4835253348188126742_n
11th Gen Honda Civic CW rear bumper color mismatch - So common! Did you ever notice? 336275035_186296350780079_9145393418539715272_n
11th Gen Honda Civic CW rear bumper color mismatch - So common! Did you ever notice? 487304859_1162741371978051_5189221753136634521_n
11th Gen Honda Civic CW rear bumper color mismatch - So common! Did you ever notice? 488725122_9396356383753238_8592390915881537860_n
11th Gen Honda Civic CW rear bumper color mismatch - So common! Did you ever notice? 488863381_9577174905693994_287850244987422341_n
11th Gen Honda Civic CW rear bumper color mismatch - So common! Did you ever notice? 492086351_3022231354607886_9214350638690819409_n
11th Gen Honda Civic CW rear bumper color mismatch - So common! Did you ever notice? 493043113_9873229089457295_1332776340433474167_n
11th Gen Honda Civic CW rear bumper color mismatch - So common! Did you ever notice? 495375489_10162653990401212_4044230141374927243_n
11th Gen Honda Civic CW rear bumper color mismatch - So common! Did you ever notice? 499075399_10161340448382031_290438317188661260_n
11th Gen Honda Civic CW rear bumper color mismatch - So common! Did you ever notice? 499262983_9757442320976413_5542381203744955631_n
11th Gen Honda Civic CW rear bumper color mismatch - So common! Did you ever notice? 499979596_3623913367903008_8198839795354411371_n
11th Gen Honda Civic CW rear bumper color mismatch - So common! Did you ever notice? 503265767_24047472031516472_5727971707742468454_n
11th Gen Honda Civic CW rear bumper color mismatch - So common! Did you ever notice? bumper
ctechauto
A few of those pictures I dont see it being even a shade off. Regardless, plastic parts commonly dont ever match 100% to its metal adjacent panels. The formulation, mixing, spraying will have to be adjusted for each type of material you're spraying. This typically doesnt happen on a mass production line. Same can be said for the front bumper vs fender. And the trunk is metal...
Its not just on these cars, either.
Jim
Tacoma trd pro, Mustang gt350R
Yup, usually bumpers or plastic parts dont match perfectly. Some manufacturers are way worse at matching.
I'll have to check my CW now, super noticeable in those pictures but I can't help but feel that I've never really noticed it. Some of those pictures also have inconsistent lighting, so that may be playing a factor
Jim
Its also the lighting in which its viewed, which can amplify the color difference. Mine is pretty good.
Nothing
2023 CW FL5 #5044
Hatch is resin
My bumper is closer to the rear quarter than the hatch. The fact that the hatch requires a lot of force from the internal handle to close, yet doesn't like to latch, bothers me more than the shade mismatch.
ctechauto
Hatch is resin
The hatch is certainly aluminum. Had the wing and all interior hatch panels off many times now. But I agree it does require some force to close
ctechauto
Its actually a combination of materials. Certain parts have aluminum and others are the composite. At least Honda claims as such.
Ah, that could be true and I just didnt see any part that wasnt aluminum then
Hatch is resin
Adjust the bump stops on the sides of the hatch door. Mine were loose from the factory, so when I hit bumps the latch would “clink.” If they’re lowered too much, they can probably interfere with the latch catching properly (when closing). I think the latch position has some adjustability as well.
Yep. SUPER common, especially on vehicles that aren’t $$$. It’s not difficult to spot (including on others makes/models) when you know what to look for.
Jim
I had a dodge challenger 2011 392 in that green color. The bumper was a shade different than the body. That wasn't the worse part about that car. The actual body panels rippled on their own. You wanna talk about something that got to me. That did. Id get paintless dent removal and it would come right back. Finally gave up on it.
