FL5 Motec ECUs released
Allthingsfl5
indiana
2025 CW FL5
Taken from 4pistons website.
“M1 PLUG-IN SOLUTION NOW AVAILABLE FOR 2017+ HONDA CIVIC TYPE-R
MoTeC's Honda Civic Type-R Engine Plug-In ECU Kit is a fully programmable replacement for the factory-fitted engine ECU. No rewiring is necessary because the kit plugs straight into the stock wiring harness and uses the original sensors and fuel system.
All essential Original Equipment (OE) functions are maintained, including dashboard, traction control and other stock systems.
Compatibility
This Plug-In ECU kit has been designed for compatibility with the Honda Civic Type-R in all geographic regions, years 2017+.
Features
Intelligent, next generation engine control
Quick, plug-in installation
Easy tuning with MoTeC's M1 Tune software*
Full integration with factory systems
Full cruise control capability
M1 Level 1 Data Logging with 250 MB on board memory
Data analysis via MoTeC's world renowned i2 software
Kit Contents:
Honda Civic Type-R Adaptor Box
Honda Civic Type-R Breakout Loom
M1 Adaptor Stub Looms
Network Cable RJ45
LTC-NTK Lambda to CAN module”
11th Gen Honda Civic FL5 Motec ECUs released IMG_0110
J_D
J
Montreal
Based on other motec prices maybe I'll just run a bad tune then throw in a crate engine when it blows :p
ABPDE5
New England
2024 Integra Type-S
I know there were some issues with AC, etc. for more recent FK8 MYs. I wonder how well the FL5 firmware works OOTB. Hope anyone who decides to run this chimes in!
