- Joined
- Apr 24, 2018
- Threads
- 47
- Messages
- 949
- Reaction score
- 1,377
- Location
- USA
- Website
- twostepperformance.com
- Vehicle(s)
- 2023 Type R
Just wanted to chime in and say that not all coilovers are more harsh, and that it does depend on how the coilovers are setup by the manufacturer. The default spring rates and dampening on the RS-R Best Active coilovers were significant softer than the factory Type R suspension, so much so that I immediately ordered a stiffer set of replacement springs to use with the RS-R electronic dampers. It definitely surprised me.The moment you swap out OEM stock parts for a mod, it’s going to be harsher in terms of NVH. With coilovers, it’s going to be harsher than stock. Every coilover has higher spring rates and you best hope that the valving on the struts is good for the spring rates. That’s where the different brands come into play.
Ask yourself whether you want to sacrifice ride comfort for the X amount of days at the track and what your normal commute road conditions are like before you spend the money.
I have Ohlins DFV on my S2000. Absolutely awesome at the track. Absolutely painful driving on the street.
