Gambit intercooler kit FL5
Gambit
Tony
Hi all,
I’m Tony, alias GAMBIT and I would like to introduce you to my Do it Yourself (DIY) intercooler kit. I’ll call it “Gambit’s FL5 intercooler kit”. A kit meant for the home DIY’er and done at a budget suitable for street as a mild upgrade over the OE 'MAHLE' intercooler fitted from the factory.
It's an open source intercooler kit for you to build yourself as a DIY'er.
The benefit of this DIY kit for the community is that all parts are available on ebay or universally available online. You can mix and match whatever parts you have spare such as silicon hoses, clamps, pipes etc to make it work.
At the heart of it, is an off the shelf PWR racer intercooler, measuring 600mmx200mmx68mm with 2.5" inlet and outlets and is tube and fin. This is crucial for maximum airflow to the radiator to aid cooling in hotter climates like what we get in Australia.
I have it mounted to the PRL hardpipe kit. Connecting to the silicon joiners and have set aside the PRL cast elbows.
11th Gen Honda Civic Gambit intercooler kit FL5 i-mkVzFXn-L
DescriptionCost AUDCost in USD @ 0.67 rate to AUDLink
PWR racer intercooler1040696.8https://pwrshop.au/products/racer-series-intercooler-core-size-600-x-200-x-68mm-2-5-outlets and ebay https://shorturl.at/KROvZ
T bolt clamps x6 to suit hoses5738.19
Silicon hose 63mm to 70mm 90 degree2416.08
Mandrel bend 70mm 90 degree3523.45
Mandrel bend 57mm 90 degree3523.45
Silicon hose 63mm to 57mm 90 degree2818.76
Intercooler mounts2222
Carbon side shrouds3020.1
Total$1271$858
PWR racer core has a unique tube and fin design as pictured
11th Gen Honda Civic Gambit intercooler kit FL5 i-k4xBH7r-L
There are no holes cut into the factory crash bar, i have just utilised the exisiting holes to add two mounts to fix the intercooler in place. These two mounts were L plates from the local hardware store with slots that i drilled to help align and move the intercooler up and down and left to right.
11th Gen Honda Civic Gambit intercooler kit FL5 i-w4pj2gd-L
I was not happy with my home job, so i sent it off to be CNC cut and folded for a professional finish:
11th Gen Honda Civic Gambit intercooler kit FL5 i-CsBVTkd-L
11th Gen Honda Civic Gambit intercooler kit FL5 i-c7gBcD5-L
11th Gen Honda Civic Gambit intercooler kit FL5 i-D769g6v-L
Using a Mishimoto 78-70mm T-clamp, which i have since changed to tension clamps, in order to secure the silicon hoses.
11th Gen Honda Civic Gambit intercooler kit FL5 i-QCbq3b6-L
From the RHS the silicon PRL hose connects to a mandrel bend which then connects to the silicon hose at the intercooler as per below:
11th Gen Honda Civic Gambit intercooler kit FL5 i-SjT8KFZ-L
With the front bar back on there is plenty of clearance for the intercooler:
11th Gen Honda Civic Gambit intercooler kit FL5 i-MNz6dzh-L
I was not happy with the gap between the sides and the intercooler so i made up an air guide shroud from carbon fibre sheet to help direct airflow to the intercooler:
11th Gen Honda Civic Gambit intercooler kit FL5 i-Bp7fNKS-L
All mounted up and the fitment is great:
11th Gen Honda Civic Gambit intercooler kit FL5 i-jKGJrqW-L
The jury is still out on the full impact on IAT and IAT2 as i am also running my Gambit intake kit. On the road vs on the dyno vs on the track may produce different results, so i need to continue data logging and validate what it is doing across all conditions.
Having said that, when you compare cost of this approach to other bolt in intercoolers there is value in this approach.
Here is a comparison table i put together to compare, sorting by price:
TypeLenghtWidthDepthFrontal area cm2Volumn litresPrice AUDPrice USDarea x volumnPrice ratio (AxV)
Gambit PWR racer tube and fin core60020068120008160$1,3008719792075.32
Wagner tube and fin580400702320016240$1,400938376768269.12
AIRTEC bar and plate7001901301330017290$1,450972229957158.59
PRL bar and plate7201841091324814440$1,6001072191305119.57
J's racing tube and fin7001721001204012040$2,600174214496255.75
PWR tube and fin elite bolt in700181871267011023$2,600174213966053.72
HKS FK8 tube and fin6951781001237112371$2,700180915304256.68
HKS FL5 tube and fin69517810012371123711530420.00
OE64016065102406656$0681570.00
Hi all,
Total$1271$858
Wagner bar and plate580400702320016240$1,400938376768269.12
Very cool! Most of the IAT differences will be appreciated at speed. On a dyno or standing still it will creep up like everything else in this car temp related.
Cool stuff, man! Good on you for undertaking these diy projects and thank you for sharing them with us! I’m curious to read what you see with IATs, etc.
Yeah this is very cool, I have been thinking if going the custom route.
Gambit
Tony
Thanks all. I’m only just learning Hondata as only recently had it installed. This is first initial logs, have since updated to the beta version and need another clean logging session when time allows as seeing funky things with some sensors showing and others not. So take with as an initial view.
11th Gen Honda Civic Gambit intercooler kit FL5 IMG_9737
11th Gen Honda Civic Gambit intercooler kit FL5 IMG_9736
Tougefl5
I'm confused. Did you just buy the core from pwr and make your own end tanks. Then purchase the hoses, pipes and clamps and design fixtures and call it DIY?
MSUGeoman
Josh
Tennessee
2023 Civic Type R #2486
Just to clarify, the Wagner IC is tube and fin, have one myself and vouch it’s true.
Gambit
Tony
The PWR intercooler includes the end tanks, so bolts in complete as one whole unit. Then just added in hoses, pipes, clamps and brackets.
NoviceFL5owner
Keith Green
stl
Good job. I didn't even know about some of these intercoolers. Might have to look into the tube and fin ones.
