Garmin Catalyst mount
ttccnn49
Steve
florida
Street triple 765RS
Finally pull the trigger on the garmin catalyst.
Is everyone using the mount come with it or what are some solid option to make sure it stays.
Thanks in advance.
alSpeed2k
Alex
The 604
Honda S2000CR, Civic Type R
Stock mount with a longer arm so I can install it on the bottom left corner of my windshield.
I am using one of these (which is similar to pro clip but cheaper, the pro clip was sold out so I tried this brand and it has been ok)
https://www.atachmounts.com/Honda-Civic-Phone-Mount_p_535.html
I can get a picture if you would like, I have it mounted straight so its not pointed at me but can use some of the hardware to get it pointed at driver
Edit - had a pic on my phone
11th Gen Honda Civic Garmin Catalyst mount 044B2BE8-FC05-4713-9669-18364B48070D
Cables not in the picture but I run a short cable for power then the og camera cable down and on over the door and visor plugged into camera, as stealthy as I can get it so I can easily remove it when I don't want to use the garmin. I leave the clip plugged in always
