rondre3000
San Diego, CA
18x10 +40
265/35/18 Michelin Pilot Sport All Season 4
coilovers -3 front camber / -2 rear camber
Looks so good. I hope someone makes an aggressive duckbill hatch spoiler like ones I've seen for 10th gen Civics. I really liked the CaRuse Design one.
Rambler
FL5 Type R
Anyone with Swift/Eibach Pro/Spoon springs have passengers in your car often and have any tire rubbing issues?
Anthonyfa18
Anthony Mark
Laval Quebec Canada
Honda’s
Hi I a look for info
I am looking to order new
spoon sw388 18x10 Et40
I will be running spoon spring with oem shocks
As for tires I am look at
265/35/18
BRIDGESTONE POTENZA RE-71RS
YOKOHAMA ADVAN APEX V601
YOKOHAMA ADVAN NEOVA AD09
YOKOHAMA ADVAN A052
Or
275/35/18
The reason I put the tires is because after watch both video PhoThottel
He is running coil over on his car I would like to run spoon spring,​
will I have any issue with rubbing ??? Will I need pull the pin on the front shock tower??​
Do I need to buy any camber arms if so what suggestions do you guys have?​
thanks​
neildrives
Neil
Bay Area, CA
2023 CW FL5 Type R #8960
265/35/18
YOKOHAMA ADVAN A052
Or
275/35/18
thanks​
Running 265/35/18 AD09 with God-spec on stock camber, lowered on Swift Springs. No rubbing.
Personally I think 275 tires look better on these wheels because 265 look a tiny bit stretched but can't say if they will rub on stock camber.
SKINNIE
DFW TX
ISF, 23' BB FL5
Figured I'd add mine in here too! been hoarding this set for a while.
18x10 +41 TE37 OG in OG Bronze
275/35/18 Michelin PSAS4
H&R springs, EVS front camber joints. No rubbing at all
Been on the hunt waiting for a set of the OGs to pop up since I got my FL5 in 2023 lol
neildrives
Neil
Bay Area, CA
You think the front camber adjustment is needed on a 275 tire?
hson10
Hans
San Jose, CA
'23 BB FL5 Type R
Definitely waited quite a while to snag mine haha- OG bronze in concave face is getting quite hard to find in good condition! Mine has a little bit of wear here and there but still 8.5/10 😊
Yeah I think so - I'm at a touch more than -3 in the front and I feel like it would rub at anything less than -3. I guess would depend on the height / suspension itself too.
rondre3000
San Diego, CA
Most would say no. Without pulling the alignment pins, you should be at or under 2* of camber...which is within stock spec on an FL5.
Unless you're running a large/wide tire brand you shouldn't be rubbing. I ran a 275/35/18 Nitto 555 G2 on Sportline springs and didn't rub at all at 2* of camber all around.
HECTOFL5TYPER
Hector
2025 TYPE R
So I’m in the fence for CE28N Plus, how ever I’m having a hard time deciding the specs I’m
Between 18x9.5 +38 and 18x10 +40, suspension is stock I’m upgrading to spoon springs soon. I do like the concave on the 18x9.5 +38 but I believe it’s a face 3. And the 18x10 +40 is a face 4 if I’m correct. What would the benefits from one to the other. I do plan on running 265 tire. Thanks for any suggestions.
rondre3000
San Diego, CA
For me, the reason to run thr 18x9.5 +38 set up would be cost and availability. Otherwise I'm running the God Spec all day, every day and on a 275 tire. 265 on a 10" wide tire will have a slight stretch to it unless it is a bigger tire.
HECTOFL5TYPER
Hector
2025 TYPE R
Ok, so out of both wheels which one has the most lip ? God Spec or 18x9.5 +38
rondre3000
San Diego, CA
10" wide wheel has the potential for more lip, but this would be dependant on other factors. I think if you confirm one wheel has face-3 and the other is face-4, you'd be happier with face-4.
Jhatmaker
Jesse
Poway, CA
2025 civic type r
Outstanding fitment on this thread. Any reason 19x10 on 265/30 tire with 39 offset would be a concern? According to fitment calculator its nearly identical but am unsure why I dont see anyone opt for a 19" package other than tire prices, availability and comfort vs and 18 with 35 wall.
