Gruppe M intake questions
CivR
Chris
Washington
currently have the Gruppe M intake for the FL5 Type R that I haven’t installed yet. Wondering if the Infinity Designs or Eventuri carbon inlet pipes would work with the Gruppe M intake. Or what other aftermarket inlet pipes work with the Gruppe M. Thank you in advance for sharing your thoughts!
CivR
Chris
Washington
Eventuri inlet mates perfectly when using the GruppeM intake. Here is a post install PIC of both.
Here is another PIC after adding additional shielding.
Basically, whatever inlet pipe that mirrors the OEM connection point on the intake side will work.
awesome thank you. That is what I was figuring from pictures it looks like it met up with the stock connection point. I like the one piece look over the two piece set up that PRL has. But for the price wanted to be sure. Appreciate you!
coldradio1
Oliver
Nashville, TN
I’m holding out for a few months. I heard there may be a new titanium option coming out soon. While I like the Eventuri inlet, I think the difference in weave would bother me. 😂
CivR
Chris
Washington
difference in weave could be an issue. But what I dislike more is the amount of connect points between the turbo and the intake housing. I think the single piece with Eventuri inlet cleans it up a lot.
I ended up going with the infinity designs inlet pipe though. I’ll post up pictures once I have everything delivered and installed.
