- Thread starter
- #1
2023 Civic SI, 12,000 miles. I have a TSP-Stage 1 tune, typically run map 1 or 2. Shortly after installing the tune and monitoring, I was noticing fairly high positive STFT spikes off-throttle in excess of 20%. I did a once over the car for vacuum leaks and cleaned the MAF with no change. I had a K&N typhoon intake, and after seeing the step in the air pipe right after the MAF, I assumed this was contributing to some of the issue as I have up to 6% STFT correction at idle that will increase the LTFT if left to idle. As I would drive, the LTFT will equalize out, typically around 1-3%, but I've never seen it trend zero. No real driveability issues, so I have accepted for what it is and have been monitoring here and there with tunerview.
I since replaced the intake with the PRL HVI stock-MAF unit with a PRL Turbo inlet pipe. This does not appear to have changed this trend. I've walked the car up and down for vacuum leaks, and replaced the vacuum hose clamp the rear of the valve cover as this hose was fairly easy to pull-off but I couldn't verify a leak. This appears to be present across several tunes on the Ktuner platform on my car, including the stock one. I have not yet tried a tune with rev-hang re-enabled yet. I have attached two data logs, one from april, and one from today. The april log was with the old intake (50F outside), and today was with the new one (87F outside and humid). I've never seen STFT spike this high on other cars that I have owned, but I am also not sure if I have datalogged to this level of resolution, either. I would appreciate another set of eyes for those willing to take a look.
