Si Hondata CANFlex-11thGen1.5
Hondata
Hondata
Torrance California
www.hondata.com
Introducing Hondata CANFlex for your 11th gen Si, the ultimate flex fuel solution for unleashing the full potential of your turbocharged vehicle. Experience easily obtainable power gains, thanks to advanced technology that optimizes fuel combustion for increased horsepower and torque. Delivering the performance you crave. All calibrations are designed for stock Hondas (with stock intake and exhaust). Hondata CANFlex gives you more power than any bolt on. Fill your car with pump gas or Flex fuel anywhere, anytime. Hondata's software gives you the maximum benefit on the least expensive fuel you can buy. Hondata CANFlex is a 49 state SEMA certified solution for running flex fuel (E85) on turbo 1.5 and 2.0 liter Honda and Acura vehicles.
The 11th Gen Civic and Integra A-Apec use an engine very similar to the Accord 1.5. It has VTEC and a better turbo. Hondata CANFlex makes the 11th gen Civic much more responsive and exciting to drive while keeping the stock intake, cat and passing 49 state emissions. This CANFlex upgrade delivers a conservative yet exciting upgrade to your daily driver with 45 more hp.
You can purchase at our online store or through our various dealers
Youtube Video
11th Gen Honda Civic Hondata CANFlex-11thGen1.5 hondata-canflex-22si-stock-and-e85
chopsuey34
West Michigan
Hi Doug / Hondata, does the tune adjust power for different proportions of pump gas and flex fuel? Will it adjust power down to, say 255hp, if the gas tank has half gas, half ethanol in it?
#notDoug
But to answer your question, yes. That is the beauty of flex fuel tuning.
chopsuey34
West Michigan
#notDoug
Thanks! Does the CANFlex come with a method of flashing the ECU or not since it comes with the tune? Will I need to buy both the FlashPro and the CANFlex? Sorry, new to this flex fuel stuff.
The FlashPro device would be required as well.
Hondata
Hondata
Hondata
Torrance California
www.hondata.com
#is doug
The Si was tuned for all levels of ethanol from pump to E85. Adjustment is automatic. Our goal was a safe conservative torque curve. Keeping the torque curve flat means robust peak power. CANFlex is the next best power adder after the FlashPro and is 49 state legal. You need a FlashPro or a dealer with their dealer FlashPro who can install the calibration at a lower price.
This can be tuned to make a lot more power and torque, but for maximum power and torque you need a built engine. What breaks engines is torque, not power. There is no need to remove the catalytic converter.
Do a search for "Hondata Youtube Torque Talk" if this link does not work.
11th Gen Honda Civic Hondata CANFlex-11thGen1.5 hondata-canflex-22si-stock-e85 merged
pknrfe1
Carlos
san antonio, texas
23 Civic Si
I was looking into this flex fuel option, but I believe I need to upgrade my engine before I continue with the mods. I just got off the dyno on monday, FBO (stock turbo) and phearable 1.5R tune, and I’m making 257whp and 310lb-ft. Also looking at upgrading my clutch pretty soon. If I build the engine, how much power gains can be expected with the canflex on a E85 FBO custom tune? TIA!
11th Gen Honda Civic Hondata CANFlex-11thGen1.5 IMG_9275
