Hondata
Hondata
Torrance California
www.hondata.com
CARB FLASHPRO
We have been working hard testing and developing the CARB tunes for the 2022 Civic Si. The performance gains are huge with a simple upload from our Plug-N-Play FlashPro system. Our Si now has over 1,000 miles and the development was done with California 91 octane.
*EPA/CARB Status California emissions pending. This product will be certified to be used on street vehicles within the USA.
Important Note
This CARB FlashPro allows limited tuning on the preset calibrations. For competition vehicles we recommend the RACE FlashPro which allows full tuning.
Features
  • Programmable ECU interface.
  • Connects via OBDII diagnostic port.
  • USB 2.0 connection. Works with laptop or desktop.
  • 20 hours on board datalogging memory.
  • FlashProManager Windows software.
  • Check and clear diagnostic codes, monitor your engine and much more with your phone and the Hondata app
  • Custom phone and laptop gauges.
  • Dual calibration storage - upload from one of two calibrations stored in the FlashPro.
  • Flat Foot shifting
  • Traction control (Patented)
Download FlashPro Manager now and start learning
CARB 240
11th Gen Honda Civic Hondata FlashPro Civic 2022 Si+ Turbo 1.5 US | CARB Tunes hondata_flashpro_carb_240
CARB 250
11th Gen Honda Civic Hondata FlashPro Civic 2022 Si+ Turbo 1.5 US | CARB Tunes hondata_flashpro_carb_250
For more info:
https://www.hondata.com/products/flashpro?product_id=243
Hondata
Hondata
Hondata
Torrance California
www.hondata.com
Anticipated questions. "Why is this less than the preliminary tune?" " What's with the names?"
Clutch slip is related to peak torque, not power. Our calibration has a little more power than the preliminary tune but less torque. Hondata chose to engineer flat drivable torque curves to reduce the possibility of clutch slip. The name CARB 250 relates to torque level of 250 lb-ft. We will come out with a CARB 260 or 270 when a stronger clutch is available.
ValkenDnB
Luis
Civic
So are these a +3, +6, or +9 tune? I noticed the 10th gen civic had a +6 and +9 carb tune or something like that.
Hondata
Hondata
Hondata
Torrance California
www.hondata.com
Assuming the clutch issue is taken care of, what's the power potential on 93 Octane?
With a really high octane fuel 270. With 93 octane 255-260? The torque potential gain is a higher % (guess 270-280). This is a CARB tune. You are running into CAT restriction.
Hondata
Hondata
Hondata
Torrance California
www.hondata.com
No. Our tuning and labelling has changed. We are tuning and labelling for a specific torque level as it relates to clutch slip and makes it easier to tune for.
ValkenDnB
Luis
Civic
Will this tuning and labeling be transferred over to the 10th generation on flashpro software and hondata’s site as well or is the 11th gen civic a special case since it utilizes a different turbo that spools sooner and breathes longer?
OGGsr
Jamie
Richmond VA
PWP 2022 Civic Si
:applause: !!!
Thank you for providing the flexibility to use different tunes. It looks like the CARB 240 and CARB 250 tunes keep the longevity of the stock clutch in mind. At some point I see upgrading the stock clutch will be a necessity and consider it a wear item.
Hondata
Hondata
Hondata
Torrance California
www.hondata.com
Our focus is now on the 11th generation Si. There is a lot to learn and share.
Luigi
Ontario
9th Gen Si, 11th Gen SI
Is the CARB 240/250 available for download from Hondata when you purchase the hardware? Or is it an add-on to purchase regardless of the tuning device?
OGGsr
Jamie
Richmond VA
PWP 2022 Civic Si
One is for off road use the other is street legal.
I'm aware of that but was wondering which specific parameters makes one tune CARB legal. I assume anything related to emissions but which specific parameters cannot be modified?
ValkenDnB
Luis
Civic
Exactly. So basically rev hang can’t be tuned out since it’s emissions related.
