Infinity Design Intake Review
coldradio1
Oliver
Nashville, TN
Received and installed the Infinity Design intake for my FL5 today. Figured I would do a quick review and give you my thoughts on it.
Firstly, big thanks and shout out to SBX Performance for the great deal and excellent communication.
Packaging. The intake comes in two pieces. Both are well wrapped and also in a fancy ass bag. You also get a certificate of authenticity, an EDPM coupler, hose clamps, and some wiring loom for covering the MAF wiring harness. They also included in an extra EDPM coupler in my box. Not sure why, but it’s nice to have an extra.
First impressions out of the box. The airbox is freaking massive. It dwarfs the stock box and the inlet opening is significantly larger as well. The airbox interior leaves much to be desired. It’s not smooth and looks unfinished (pictured). It probably doesn’t matter much for performance, but considering how gorgeous it is on the exterior, I would expect a bit more finesse on the interior. It’s important to note that the pipe post-filter is smooth.
Installation. First of all, I would recommend a couple addition things to help with install. 1) Honda uses shear-off hose clamps in various parts of the engine bay. One of which will require loosening. I highly recommend getting a set of Engineer PZ-58 pliers (pictured). They make short work of turning the sheared end of the clamp. 2) the hose clamp that Infinity includes to replace this sheared clamp, if terrible. It’s too small and cannot be used. So, you’ll need a 8mm-10mm-ish clamp to replace it. 3) for extra protection of the MAF wiring, I recommend getting some fabric wiring tape to cover it after you put it in the looming. As for the install itself, it’s fairly straightforward. The instructions do miss a few things, but they make themselves apparent pretty easily.
Fitment. This is my only complaint. I ran into issues in two spots. 1) The rear mounting bolt didn’t want to line up easily. 2) because the airbox is so freaking big, I sits against a wiring harness for the fans along the front corner (pictured). I’m not sure how much of an issue this actually is, but I’ll be watching it regularly to see if it causes problems. I also didn’t love that it only used the rear airbox mount bolt, the front stud, and one of the bolts on the intake scoop. It seems solid and doesn’t move, but I’d still prefer if it used all the factory mounting points.
Test drive. Sound is rather conservative. Putting around town, it sounds no different from stock. When you get on it, midrange has a lovely deep tone, and the “blow off” sound is audible but not obnoxious. Very OEM+. If you are looking for something that doesn’t bring too much attention, this may be for you. Performance wise, my butt-dyno did feel a difference. Midrange and top-end do feel stronger and there seems to be less of a drop-off in power at redline.
Overall, I’m happy with it. Aside from the fitment stuff, as long as I don’t run into issues with that wiring harness, I’ll be keeping it for a while.
11th Gen Honda Civic Infinity Design Intake Review IMG_5950
11th Gen Honda Civic Infinity Design Intake Review IMG_5951
11th Gen Honda Civic Infinity Design Intake Review IMG_5961
11th Gen Honda Civic Infinity Design Intake Review IMG_5976
11th Gen Honda Civic Infinity Design Intake Review IMG_5977
typerawrr
Los Angeles, Ca
The exterior is v pretty! Do you think it was worth the coin?
Thanks for the tip on the Engineer PZ-58 pliers, some of my screws or bolts were stripped before i even tried to remove them. Going to use these for when I switch over my turbo inlet!
coldradio1
coldradio1
Oliver
Nashville, TN
It is expensive, but what isn’t for the FL5? lol. I also feel like I got a good deal on it, and I did feel gains from it. So if you want something that looks and feels more premium than the PRL, I think it’s a great option.
Zpeedster M
New York
2023 Type R FL5
The highest point of the airbox will rub on the underside of the hood, you will need some adhesive rubber cushion or else airbox will rub away the paint.
I don’t have those pliers, but I have an Engineer wire stripper for small gauge wire and they’re the best wire strippers I’ve ever used. Very high quality tools.
coldradio1
coldradio1
Oliver
Nashville, TN
I haven’t noticed contact there, but I’ll check it regularly to see if I see any marks. Thanks for the heads up
Zpeedster M
New York
2023 Type R FL5
If you place some tape on the high pts of the intake & close the hood fully it will stick to the contact point of the hood. If not then you got lucky ? Mines already rubbed off paint :confused:
SKINNIE
DFW TX
ISF, 23' BB FL5
Great option. I wish I bought the Infinity intake w/ inlet pipe when they had a sale on them. PRL is like the TE37s of the intakes. Everyone has them ?
Not to worry, it will go on sale again this fall. And you have to put a little more respect on the TE37s, in no way would I relate them to the PRL HVI ?
Tougefl5
Or you can call infinity design directly and still get the discount. That’s exactly what I did when shopping for intake. All the vendors just drop ship them. I got offered the discount twice on two different occasions.
Decided on eventuri in the end.
SBX Performance
Poughkeepsie
www.sbxperformance.com
2024 Honda Civic Type R
Hey we are an authorized dealer for them and I can do a discount. Trust me reaching out to Infinity Design for a discount isnt going to happen they are strict with pricing even for dealers and they are worth full price and they keep it that way. Message me here or on instagram @sbx_performance_llc for a special offer on them.
Also @coldradio1 thank you so much for the detailed review. I am in close contact with them and gave them all your feedback to the design team! They are great people!
@Tougefl5 In relation to drop shipping them......I ordered a big stock of them and they all sold out before they even arrived.....Same thing is happening this time...Eventuri is my second favorite intake so not a bad choice in the end
