Introducing ACUITY's New Performance Shifter Centering Spring!
baldheadracing
Craig
Canada's capital
FK8
I think you meant this video (for this thread) ;):
Just a note on something not shown on the video: The spring comes with a little tube of silicone grease. Use it when doing the install. Put grease on the (new) spring, all over the rocker shaft, basically anyplace where pieces are going to rub on each other.
Hellraisingvtec
CarStudio101
Maryland
www.youtube.com
2017 SI
I want to purchase these but it looks like a lot of work
It took more time the first time I removed the console but it was fairly easy. Would recommend to do base bushing and the spring at once due to everything being removed. If you have any questions, feel free to reach out. Good luck
Multaq
Nick
New York
2018 Civic LX 6SPD
Race ya! I've torn into it a few times now between console illumination, new head unit, and the bushing installs. Also, there's a few less steps with the sport compared to the Si. I can skip 11b-11f and just pull the console since there's no usb under the armrest.
Yea I have an LX, So it is pretty easy to remove because there are less wires to deal with.
IDriveanSi
Gerry
Los Angeles, California
2018 civic si
I've recently heard that the Stock type r shifters spring is almost identical to the acuity centering spring. Can anyone with a type R confirm this?
ACUITY
ACUITY
Russell
Baton Rouge, LA
2017 Si
Closer than the sport model, but not the same. The springs we sell increase centering force by about 100% on the Sport models and by 20% on the Si and CTR (Si and CTR use the same spring from the factory).
~russ
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
98 Civic EX with SI Conversion-Sold, 2017 Civic Si Sedan
~russ
Did you guys make an updated centering spring?
ACUITY
ACUITY
Russell
Baton Rouge, LA
2017 Si
This is a quote in regards to the centering spring upgrade we sell for the OEM shifters (SKU 1918).
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
I meant you guys made 2 versions of the centering spring correct? Originall it was just the spring with no rubber sleeving and now has rubber sleeving
ACUITY
ACUITY
Russell
Baton Rouge, LA
2017 Si
I meant you guys made 2 versions of the centering spring correct? Originally it was just the spring with no rubber sleeving and now has rubber sleeving
Ah ok. Yes, that's correct. The version with the rubber sleeves just reduces play in neutral and sound from centering a touch more compared to OEM springs and our old design. The new version with rubber started shipping quite a while back though, perhaps as 9-12 months back.
Jay_Tech
Jarrett
Kawartha Lakes Ontario
2019 Honda Civic Si, 2024 Honda Civic Type R
Just installed this yesterday on my Si. Install was actually super easy and the difference is definitely noticeable. Love how the shifter feels. Now once I finish my other mods I have lined up I will probably end up getting the full shifter assembly as I have only ever heard great things.
ManitobaSI
Scott
Manitoba, Canada
2017 Civic SI
Hello, I am very new to car modifications and the first time taking everything apart took me four hours just learning and being careful. I used the Acuity plastic tool kit and an angle hook pick like the instructions suggest. Putting everything back together took about 15 min. I realized I had a wire tucked incorrectly at almost the end of reassembly and had to take everything apart again and that only took about 15 min to disassemble again, as I now knew how all the various clips and harnesses had to be disconnected and where all the clips are. It was a big job but well worth it!
ACUITY
ACUITY
Russell
Baton Rouge, LA
2017 Si
Thank you so much for sharing your experience. This echos what we often tell people who are nervous. The first time, especially if you are new to removing interior panels, is a slow process, but after you've done it once, you're wayyyy faster. Glad the mods are treating you well! :)
~Russ
pinhead66
Bay Area, CA
2019 Civic Si Sedan, 2025 CRV Hybrid Sport-L
Over the weekend I installed my CTR shifter in my Si. I put in the centering spring with the rubber sleeves but it would make a slight squeaking sound when pushing to one side. Used the provided lube on the section of the rubber sleeve that was brushing up against the shifter base but didn't help. Any advice on this? I just went ahead installed my shifter with the OEM CTR spring because I didn't want to possibly disassemble my center area again. Put in the solid base bushings as well. Out of curiosity I installed the acuity spring on my now removed Si shifter and it did the same squeak as well.
ACUITY
ACUITY
Russell
Baton Rouge, LA
2017 Si
Hmmm, that's unusual. Chances are the spot you thought was causing a squeak was not it. Generally, grease will resolve a minor squeak. I'd see if perhaps the source is another location. If you are in need of more grease, we can help with that, or if you think for some reason you may have a bad unit, please reach out via our site and inquire about exchanging it. I've never run into one of these with an issue like this, so I'm guessing the grease in another location should resolve it, but we are here to help if that does not. :)
~Russ
