J's Racing Reinforced Torque Rod
maranelloboy05
Chris
Austin, TX
2025 FL5 (Incoming), 2007 S2000
AspecR
Stefan
maranelloboy05
maranelloboy05
Chris
Austin, TX
Awesome, exactly what I was looking for!
MSUGeoman
Josh
Tennessee
2023 Civic Type R #2486
Good looking set of kit they offer, assuming they sell through dealers since there is no pricing on their website? Curious to see what their stuff costs, at some point will start going through the suspension and remaining powertrain mounts to get everything bumping to the same groove 😎
cryptolime
Wilmington, NC
yea, i'm wondering how you even buy it
zumbooruk
Ventura CA
Has anyone used this one instead of the PRL rear mount? I'm an admitted JDM-addict so always try to use known JDM tuners parts where possible, logic be damned. Did some searching and haven't seen any references to this part, looks like its 20% stiffer than OEM, curious how that compares to PRL as well.
https://www.jsracing.co.jp/js2/inde...xSHASHU=53&xPARENT=95&xNO=EMS-L5-RR&xKEYWORD=
The main reason I went with PRL was that they use EDPM (I don't recall which other RMM manufacturer had replacement bushings for sale, and recommended replacing the bushings every few years...)
Why EPDM?
EPDM is the perfect bushing material because of its high resistance to outside atmospheric elements (heat, ozone, weather), chemicals, solvents, abrasives, tearing and vibration. Because EPDM has a higher density than urethane, this means we are able to use a softer/lower durometer bushing to keep engine vibration to a minimum, all while improving rigidity in comparison to the factory mount(s). Unlike urethane bushing inserts, EPDM bushings will not mushroom, wallow out or breakdown over time with use.
https://prlmotorsports.com/products/2023-honda-civic-type-r-fl5-rear-engine-mount-upgrade
