iforgettopee
- First Name
- jeff
- Joined
- Feb 25, 2025
- Threads
- 10
- Messages
- 219
- Reaction score
- 439
- Location
- los angeles
- Vehicle(s)
- FL5
drop looks good - just put some weights in the trunk to level out the rear haha
you could also play around with a thin spring pad for the rear spring too (maybe remove it all together if you're not worried about noise)
assuming the rear spring pad is the same as the FL5 - I measured it at 60mm ID x 90mm OD
I bought a thicker "rubber o-ring" off ebay to raise the rear of my car
