Last of the manual NA Civics
iforgettopee
jeff
los angeles
drop looks good - just put some weights in the trunk to level out the rear haha
you could also play around with a thin spring pad for the rear spring too (maybe remove it all together if you're not worried about noise)
assuming the rear spring pad is the same as the FL5 - I measured it at 60mm ID x 90mm OD
I bought a thicker "rubber o-ring" off ebay to raise the rear of my car
HKSpeed
HKSpeed
Orange County, CA
FL2 6MT
Installed Si front calipers, pads, and rotors. Si is 12.3". Non-Si is 11.1". Si pads are wider and taller. Only modification is bending back the dust shield. Reused my stock brake lines and banjo bolts. 2022+ Si front brakes are also found on 2023+ Acura Integra (not Type S) and 2018+ Accord Sport/Touring. I didn't notice an improvement after 50 miles of daily driving, which didn't surprise me. I did this mod for modding sake. 😅
11th Gen Honda Civic Last of the manual NA Civics 1767107213931-z9
11th Gen Honda Civic Last of the manual NA Civics 1767107178674-a1
11th Gen Honda Civic Last of the manual NA Civics 1767107201975-3f
HKSpeed
HKSpeed
Orange County, CA
FL2 6MT
Been 5 months since my last post. No major additions.
I painted the mirror covers red. I also added a SpoilerKing upper hatch spoiler, painted white.
11th Gen Honda Civic Last of the manual NA Civics 1779463277508-4h
11th Gen Honda Civic Last of the manual NA Civics 1779463285746-qu
I recently replaced the faded and cracked front lip with a fresh one (same design).
11th Gen Honda Civic Last of the manual NA Civics 1779463305240-xh
Got a Hawkdown knob, which is a copy of the Battlecraft knob.
11th Gen Honda Civic Last of the manual NA Civics 1779463358504-a3
I'm down to 4 knobs. I sold the Spoon (too thin) and Acuity (too thick).
11th Gen Honda Civic Last of the manual NA Civics 1779463891196-07
