Limp Mode? P0087 Fuel Rail Pressure Low
89Sem
Sean
Philadelphia area
2026 Honda Civic Type R
2026 1,600 miles
Driving today doing a little pull on an on ramp Dashboard lights up like a Christmas Tree - Emission Problem reduced speed and rpm - See dealer, Rev Match disabled, brake system light and check engine light came on. WTF?! I think to myself. Make it home turned it off, back on the brake system warning went away, read the codes and I get P0087 Fuel Rail Pressure Low. Did a quick search there’s no recall on my VIN but I noticed there was a fuel pump recall a while back?
After cycling the power went for a quick drive and it drives and revs fine. CEL and warning still on.
I’ve had the car from new, 2 miles and after the break in. At WOT at around 5000rpm be it 5100-5200 there’s been a brief but noticeable hesitation under heave acceleration, like ans if you let off the accelerator half way real quick and back on, Initially I thought it was just the power band curve but maybe not?
anyone with any insight? Obviously well within warranty. Do I reset the CEL and see if it comes back or take it in and have it investigated?
Car is stock.
11th Gen Honda Civic Limp Mode? P0087 Fuel Rail Pressure Low IMG_1325
Kaliwarrior
James
United Kingdom
FL5 Type R Championship White
2026 1,600 miles
Car is stock.
Take it in to the dealership. From what I've read online the High Pressure Fuel Pump is still a problem on these, carrying over from the FK8. I think a few guys have gotten local dealers to change the pump and their issues disappeared. If anyone else has any ideas they can chime in, but thats my two pennies (cents) worth.
Aggressive maneuvers with low fuel tank levels can result in reduced fuel pressure. Forum members mention track day fuel starvation issues somewhere below 1/2 full.
tacthecat
Cheshire, MA
'12 Civic Si Sedan, '24 Elantra N 8-DCT
With multiple alerts, I'd also check the battery state of charge and connections.
mitchell eckert
mitchell
pickerington ohio
2026 civic type R
Do you have ability to read freeze frame data on your tool? If it’s stock no mods at all an under warranty might as well goto Honda if you clear codes you’ll get your rev match back but if Honda can’t recreate complaint even with warranty you’ll pay the diag. Si if you don’t have a good tool with bidirectional controls a can read freeze frame data yourself don’t touch it goto Honda. If you have proper tools you can live test the hpfp an look at freeze data for each injector. If car ran after lights came on my money is on an injector not a pump if pump faulted it wouldn be jus low pressure it would be 0 an it would have died a non started. So prolly injector an also pull spark plugs an even borescope each bc it could be start of infamous head gasket coolant blow by pusses off injector an it all falls like dominos so goto Honda an make them check it all
