Misfire Cyl 2&3
nodnarb901
Brandon
Olive Branch, MS
I have a 23 FL5 with 15k miles. Has Hondata base 93 octane tune on it.
I have been having an issue where the check engine light comes on every once an a while when I start it after the car has been sitting for a while.
Always has codes for misfires on cylinders 2 and 3. Car feels like it misifres for a second after starting then smoothes out.
A few months ago I washed my engine and got water in the spark plug tubes and had to replace all spark plugs and two coils.
Before I take it to Honda for a warranty claim, I want to make sure this problem I'm having now is not something I caused like last time.
I swapped the coils from cylinders 2 and 3 to cylinders 1 and 4 about a week ago. This morning CEL came on, codes for misifre cylinders 2 and 3 so
now I can rule out the coils that I was affraid may have had some lingering issues due to my water issue.
Next I'm going to do the same with the plugs and see if the misfire jumps to the cylinders I move them to.
One of my techs at work (Maserati not Honda lol) thinks it may be my fuel injectors leaking when the car is off.
Has anyone else had an issue like this?
A tech I know at Acura said they had to replace injectors on a Type S Integra for the same thing.
Lukeklaas
Luke
Fk8
Yeah water I had the same thing on fk8. Replace spark plugs and your probably fine
Stanleywinthrop
Usa
10th gen
Leaky injectors was definitely a thing for early 1.5s, but I don't know about the 2.0s. But if they are leaking, you'd see problems with oil dilution. I hate to bring this up, but to might want to check your coolant level if the swapping the plugs does nothing.
nodnarb901
nodnarb901
Brandon
Olive Branch, MS
thanks for the input. Checked coolant level looked good.
twice Now when I start it, it misfires badly , ck engine light flashes. If I turn off and immediately restart misfire goes away. Then runs fine for 3-4 key cycles then, acts up again.
‘as much as I hate to take it to the dealer , guess I’ll bring it in this week and have them look at it.
i app the input from everyone here.?
Stanleywinthrop
Usa
10th gen
Since you are under warranty that's the best course of action.
If you weren't the next step would be to put a camera in the cylinders to check for the leaky injectors.
chemreac
Jason
Baltimore
'25 boost blue CTR
update us on the warranty if that is the route, interested to hear what they say since its a potential engine ecu with a jailbroken ecu
When you had to replace the 2 ignition coils, which ones did you replace? Did you have a similar problem when the coils were replaced? If it was # 2 and 3, I wonder if there’s a corrosion problem at the wire connector to those coils?
Bigfx
2024 civic type r
Yeah not to be that “guy” but they may not warranty any of the work with a tuned ecu. Most dealers will perform an ecu scan to see the codes and either flag the car as tuned and or deny any work as Honda may not reimburse for warranty work on a modified engine.
nodnarb901
nodnarb901
Brandon
Olive Branch, MS
Again I appreciate all the input1
The dealer I’m taking to is full of former coworkers of mine, the shop foreman, service manager and advisor, are all friends. So I have that on my side. Unless their hands are tied by Honda I should be ok.
So I don’t waste their time and potentially incur a charge, I want to check everything I can to be sure my problem is a legit warranty issue.
I may put my borescope in the cylinder to check for leaky injectors.
great idea checking for corrosion at the coils! I’ll check that too.
nodnarb901
nodnarb901
Brandon
Olive Branch, MS
update
check engine light has been off for the past two weeks.
came on again yesterday, with a code for a misfire on cylinder 4.
I noticed when this happened I get other non related indicators/ messages too, like abs, blind spot, adaptive cruise etc.
im going to test/check the battery. Wondering if the voltage is dropping too low at startup?
princers
Z
25 Type R
OP did you try swapping the plugs?
nodnarb901
nodnarb901
Brandon
Olive Branch, MS
I did, when it was misfiring on cylinders 2 and 3 I swapped the plugs to 1 & 4. Misfires stayed on cylinders 2 and 3. Now two weeks later getting a misfire on in 4.
MYK20C1
Jim
Chattanooga
Did you test the 02 sensor?
kentucky
2025 Type R
I assume it's a cold start misfire that goes away when warm? Need to start by pressure test cooling system and use boroscope to check cylinders 2/3 for coolant leaking into cylinders, funny enough it always seems to blow between cylinders 2/3. While not as bad as the 1.5's i have had some 2.0 Accords with blown head gaskets. I have not seen a Fk8 or Fl5 with issue yet. i also haven't seen any injector issues on the 2.0 either. I have an Accord right now I'm tearing down for a head gasket issue. I hope it's as easy as an injector issue for you.
nodnarb901
nodnarb901
Brandon
Olive Branch, MS
Well it hasn’t come back since February an 4k miles. I’ve since done the Phearable stage 2 tune, and haven’t had an issue? Thinking it may have been a random issue that’s ok now.
