Missing screw on the engine?
qingcong
North Carolina
2024 FL5, 2013 Si, 1991 NSX
My car has 600 miles on it and ever since I've owned it, I've smelled a bit of a burning smell after driving. I thought it would go away after whatever the smell was burned off, but it's still here. Today I finally opened up the hood after reading about people having head gasket leaks and wondered if that was the issue. I didn't see any standing oil anywhere, but I did see this part where it appears there's a screw missing. Is there supposed to be a screw here? If so, what should I do and will this have caused any damage?
11th Gen Honda Civic Missing screw on the engine? noscr
11th Gen Honda Civic Missing screw on the engine? noscrew2
RP2000R
No screw goes there on our car model.
The engine and exhaust will smell a bit as the car gets broken in and heat cycles. If it drives fine, fluids are full and no visible leaks I wouldn’t worry about it.
qingcong
qingcong
North Carolina
Good to know. I'm just curious, how do you know no screw goes there? This seems like a bit of obscure knowledge.
DRGN
in your walls
24 FL5 CTR
Semi related to OP but I was also noticing a slight burning smell after driving and thought it was from user error, but thanks for letting us know that it's part of normal break in
inb4 skill issue
