Rexpelagi
- First Name
- John
- Joined
- Jun 26, 2024
- Threads
- 6
- Messages
- 362
- Reaction score
- 465
- Location
- Nashville, TN
- Website
- www.youtube.com
- Vehicle(s)
- 2024 Type R, 2019 Model 3 Performance
Ballade camber plates should be around $500 for the set, but you can only get around -2.5° before the strut spring perch has clearance issues with the chassis. You also have to remove the front struts to put the plates on, which can be a bit of a pain.Thank you Iforgettoopee. I will check them out. I saw the camber plates on the Honda website but they want $900 plus for the set of two!
For what you are looking for I would definitely just do the lower ball joints. I would target -2.5° to -3° (you may be able to leave your alignment pins in for that) - I think that's the right range on these cars.
Here's an install video from our very own @PointByPatrol if you want to look into it more:
https://www.civicxi.com/forum/threads/evs-tuning-ball-joint-install.55492/
