"Official" Lap Times Thread
Hailw00d
Nashville, TN
2025 CTR
Model:FL5
Track Name:Barber Motorsports Park
Layout:Grand Full
Lap Time:01:40:9 (01:40.7 best, but the camera wasn't working)
Date:06-08-2025
Ambient:85F
Username:Hailw00d
Year:2025
WHP/TQ:Stock
Tire/Wheel:265/35R18 Bridgestone Potenza - Apex VS-5RS 18x10.5
Mods:N/A
Notes:Paragon R5 Pads (Front/Rear)
OE camber pins pulled
-1.7 deg front camber, zero toe front/rear
OE hood vent rain guard removed
PRL rear motor mount
Time Attack Class:NA
Video:
Traction Control:Pedal Dance
Suspension Settings:Comfort
Hailw00d
Nashville, TN
2025 CTR
Had a great time at Barber over the weekend. Unlike NCM where it was cooler, the temps (mid-80s) really highlighted the need for some cooling modifications. I could get 270+ oil temps after only a couple laps and it was clear the car was pulling power. With cooler temps and/or better cooling I think the car could do a 38/39 basically stock.
Also confirmed that my rear cupholder mount isn't going to work out long term, so enjoy the weird rear-side window camera view. Getting a decent mount sorted is next on the list.
Even with all that the car was super fun - highly recommend checking out Barber. Between the track and the facilities it's one of my favorites.
Rexpelagi
John
Nashville, TN
www.youtube.com
Nice Lap! Just FYI - you probably already know from the One Lap experience but the oil temp gauge is just a calc, not a sensor. Given you are basically stock (not sure if you are still on the OE weight oil), it's probably not far off, but coolant temps may be a better thing to watch, especially after cooling changes. @siwelnosaj has a great looking triple-pass radiator now, and may as well do the HEL oil cooler (although better options are in development).
siwelnosaj
Jason
Reno, NV
Type R
Thank you for the mention, have you seen my dual oil cooler kit I just released last week?
11th Gen Honda Civic "Official" Lap Times Thread FB_IMG_1748986677124
11th Gen Honda Civic "Official" Lap Times Thread FB_IMG_1748986680645
11th Gen Honda Civic "Official" Lap Times Thread FB_IMG_1748986687510
11th Gen Honda Civic "Official" Lap Times Thread FB_IMG_1748986690875
11th Gen Honda Civic "Official" Lap Times Thread FB_IMG_1748986684036
11th Gen Honda Civic "Official" Lap Times Thread FB_IMG_1748986705823
11th Gen Honda Civic "Official" Lap Times Thread FB_IMG_1748986693853
11th Gen Honda Civic "Official" Lap Times Thread FB_IMG_1748986702592
Rexpelagi
John
Nashville, TN
www.youtube.com
Model:FL5
Track Name:GingerMan
Layout:Full (w/10B)
Lap Time:1:38.775
Date:06-06-2025
Ambient:65° F
Username:Rexpelagi
Year:2024
WHP/TQ:400/400
Tire/Wheel:285/30R18 Front // 255/35R18 Rear; Bridgestone RE-71RS; 200TW; 18x11 ET44 Front // 18x9.5 ET35 Rear
Mods:Tune
Intake
Camber
Coilovers
Downpipe
Intercooler
Exhaust
Notes:This lap was slightly impacted by traffic, but unfortunately the surface got worse throughout the weekend, so I wasn't able to go faster.
E30 Custom Tune by https://jst-performance.com (Cobb AP - ~400whp)
18x11 ET44 Apex EC-7 Front / 18x9.5 ET35 Apex EC-7 Rear
285/30R18 RE-71RS Front / 255/35R18 RE-71RS Rear
Redshift Motorsports Custom Coilovers (Coilover Front, Spring/Shock Rear)
Karcepts 0.188" Wall Rear Anti-Roll Bar
Paragon R5 Brake Pads
HEL Oil Cooler
Radium Engineering Expansion Tank
PWR Track Spec Radiator
Acuity Reverse-Flow Radiator Hoses
WOT Performance HPT Cooling Plate
PRL HVI Intake
PRL Titanium Inlet Pipe
PRL Turbo Inlet
PRL FMIC
TSP Downpipe
PRL Mid-Pipe
Hasport Rear Motor Mount
Time Attack Class:Gridlife - Street
Video:
Suspension Settings:N/A - Coilovers
siwelnosaj
Jason
Reno, NV
Type R
I did! I wasn't sure if it was officially out or not, but it's what I was thinking of when I mentioned some better options "in development". :)
It is out and ready to be ordered! It's a 4 week lead time once the order is placed. Let me know.
Hailw00d
Nashville, TN
2025 CTR
Yeah, I'm familiar with the limitations of the OEM stuff. I'm running 5W-30 oil but otherwise everything is stock, so I'm guessing it's pretty close. At this point I don't know that it matters since the car thinks it's 270+ and is definitely pulling power.
I actually expected the coolant temps to be a bigger issue. I was mostly below 220 doing 2~3 flying laps at a time. Still going to be looking at radiators as well as the WOT oil cooler solution, which I've definitely been eyeing for the last week or so ?
Hailw00d
Nashville, TN
2025 CTR
I've definitely been looking at this over the last week. I was curious how the routing of the lines works for the dual setup? Are the coolers independent or linked together across the bumper?
siwelnosaj
Jason
Reno, NV
Type R
The
Good question, I have them linked together in series.
Rexpelagi
John
Nashville, TN
www.youtube.com
That's interesting - my coolant actual and oil calculated has been in the same range but I haven't observed power being pulled *yet* (and honestly it seemed like oil calculated wasn't being used for anything), but it also could be related to my tune vs. the factory tune.
Hailw00d
Nashville, TN
2025 CTR
My guess is that's part of the benefit of tuning. On my laps when I was cleaning stuff up on lap 2~3 I would be up through bascially every technical section and losing time on the straights vs. when the car was cool. I told myself I wasn't going to tune but it's definitely tempting.
Rexpelagi
John
Nashville, TN
www.youtube.com
My current E30 tune (and my 93oct tune from last year) runs ~2-3psi less boost than factory (but makes way more power), so that could help keep as well with keeping things a bit cooler. There are definitely a lot of calculated and actual monitors in the background (as I've learned through the tuning process with @JST Performance ) that control parameters on the stock tune in a way that can override things unexpectedly - it's definitely looking at a lot of things in the background (ie, calculated EGTs, compressor outlet temp, etc).
siwelnosaj
Jason
Reno, NV
Type R
I do think that with tuning the car will not pull power as easily. It's a double edged sword though cause now you as the driver have to be more willing to pull back if it starts to get to that point
kitwilliams117
Kit
North Carolina USA
2024 Honda Civic Type R
Model:FL5
Track Name:CMP
Layout:Full
Lap Time:1:48.29
Date:06-15-2025
Ambient:81F
Username:kitwilliams117
Year:2024
WHP/TQ:Stock
Tire/Wheel:275/35R18, Vitour P1, 200TW, Enkei TS7 18x9.5 +45
Mods:Intake
Exhaust
Notes:Stock Tune
PRL HVI
Remark Titanium exhaust
Project Mu Club Racer pads
Castrol SRF brake fluid
Eibach 25mm rear sway bar
275/35R18 Vitour P1 tires
Time Attack Class:SCCA Sport 3
Video:
Suspension Settings:Sport
