sgtmorph
- Joined
- Feb 3, 2016
- Threads
- 50
- Messages
- 661
- Reaction score
- 354
- Location
- Long Island, New York
- Vehicle(s)
- 2022 Civic Sport Hatchback (BB)
- Thread starter
- #1
Since these are super simple, here's the Honda service docs for the oil change process and refill amounts for the 1.5L and 2.0L
First, take off the splash shield.
You'll need a #3 Phillips (Yes a #3) and a flathead.
Then use a 17mm wrench or socket for the drain plug.
Please use a new crush washer with each oil change.
Honda requires drain bolt to be torqued to 30 foot pounds.
For the 2.0L, you'll fill 4.4 US quarts:
For the 1.5L, you'll fill 3.7 US quarts.
Honda says 0W-20 for both 2.0L and 1.5L
Then clean it all up, and reset your maintenance minder, and you're all set! Good luck!
