[PRL][High Volume Intake] Missing intake filter bolt
Se-BASS-tian
Sebastian
Poland
Honda Civic Type R FL5, Toyota Celica VII TS
Has anyone lost a PRL HVI filter mounting screw and knows where to get one identical to the one PRL uses in their set?
Picture:
11th Gen Honda Civic [PRL][High Volume Intake] Missing intake filter bolt 1740154371717-ef
Car00071
St. Louis, MO
2024 Integra Type S
Yep happened to me. I contacted PRL for new ones but they took a while so ended up just getting some from amazon instead. I used blue thread-locker and it has been good so far.
FL5CW
North America
Anyone missing screws shoot [email protected] an email & ask for a set of PRL2.1032.12.0. We will get you taken care of! Due to the high amount of CS tickets, sales will be able to get you guys taken care of much faster.
I reached out as Im missing a couple of bolts and one is loose. They wanted to create an invoice and bill me. I will just find something local that will work.
TypeRVA
Neal
Richmond, VA
2024 Honda Civic Type R
I have links above for what I used.
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
You should not be charged! DM your email to me & I will get it taken care of personally.
BigBird
I've heard of the issues with the screws falling out, which is not good at all and not confidence inspiring, but to add to it by charging you, or having to wait 6+ months for a design defect, that's crazy.
PRL crossed off the list.
jcm
LA
2025 SGP FL5
I have. You can find the actual screw on Amazon. I have like 100 of them now. Finding the same washer was tough so I just bought new ones that look similar.
https://a.co/d/hyCwz1X
https://a.co/d/7Jt6ydi
just to clarify here, when you open the screw page the default shown specification is M5 x 12mm, is that the correct screw or do I need to navigate to a different specification of screw shown on the page?
lost my first one today off of the air filter mounting side on the PRL HVI. looking to pick some of these up to keep on-hand along with some blue loctite...
TypeRVA
Neal
Richmond, VA
Yeah they are M5 X 0.8 X 12
PRL Motorsports
Export, PA
prlmotorsports.com
The correct screw specs are M5x0.80x16mm. We made the bolts longer. The issue with the 12mm is that the threads did not go deep enough to get the loctite to bite in the threads.
TypeRVA
Neal
Richmond, VA
Ahh the instructions on your instructions (still on your site) lost it as 12mm.
