optronix
- Joined
- Apr 5, 2023
- Threads
- 4
- Messages
- 739
- Reaction score
- 1,119
- Location
- Mid-Atlantic
- Vehicle(s)
- 2024 Integra Type S, 2023 Macan GTS, 2025 Miata Club BBR
I won't argue the Spoon spring rates aren't more suited to track use, but the camber settings are going to be pretty consistent. I'm no suspension geek and honestly try to "stay casual" and avoid dicking with those settings in sim racing games and the sort, but how I've always understood it is the science predicts that more negative camber in the rear than the front will lead to understeer.Could the under steer be spring dependant, I’m running spoon springs on mine but never got a chance to take mine on track prior to the springs being fitted. Would be gold to hear view of others that have had spoon or other springs fitted to see if it induced under steer on theirs too. I’ve had a full alignment done since fitting the springs.
You can see the added negative camber, visually (I'll concede you do have to look for it...). Here's what I think is a good example, from this thread on the Integra forums I just saw yesterday (free marketing for LMTLS, these are exceptional wheels); I don't know what the specs are on this car but I've seen similar on my car and many others that have springs but otherwise no camber correction:
The only thing you can adjust from an alignment perspective for camber on our cars is pulling the strut tower pins, which as has been stated will net you about half a degree in the front. Otherwise you'll need adjustable lower ball joints, or alternatively "top hat" camber plates with a set of coilovers. It's a relatively simple and inexpensive fix, and most folks who will be interested in track use AND modifying their cars will very likely be inclined to do both. I'm here to recommend that you absolutely do both unless you don't intend to do stuff on track...
edit: on a side note this is surely a dumb question but I have had no luck with online searches and even reached out to Whiteline and received no reply- on our cars, can you even do adjustable camber arms AND roll-center adjusters? Where exactly are they installed? I can't tell from looking at pictures and don't have the practical experience... the roll-center adjusters go on the tie-rod ends, right?? @tezzasaurusrex you surely know this...
