tuhroo
tuhroo
Today’s quick response from the Service Manager at my dealership following an inquiry about the driver’s seat.
“According to our Honda Vin Inquiry System your Vehicle may be subject to a recall affecting the driver’s seat cushion frame. It’s for squeaking, rattling or breakage of the seat frame. Currently there are no parts available for repairs. Once seat cushion frames become available, the registered owner of the vehicle will receive a notice to bring the vehicle in for replacement of the component.”
literally copy and pasted from the bulletin lol
ChrisFL5#82
Chris
OKC
Eh2,FL5
@tuhroo Hey there! Really appreciate you willing to help us all out with the Vin searches!
Any chance you could look up Vin #
JHMFL5G45PX000082
Thank you in advance!
Rad Ray
Ray
I’m speculating that the problem weld is where a round cross bar is welded to the two side plates on the seat.
Here is a picture of a fillet weld on the inner side of my drivers seat. This is the inside left side of the seat looking from the front. These welds are near the front of the seat
Here is a picture of the same area on my passengers seat (right side of seat).
So the passenger seat weld is on the outer part of the side plate and this picture shows the heat affected area. I couldn’t easily take a picture of the outer side bc of the seat trim.
My car is 1105 and NOT recalled. My thoughts are that both the passenger seat and drivers seat welds are on the outer side of the side plates and that the fillet weld visible on the inner side of the drivers seat is the “fix” that was made hastily during production.
Will someone with a sub 630 car post a picture of their drivers side inner weld area? I’m wondering if it has the inner fillet weld or not?
11th Gen Honda Civic Recall: 2023 Civic Type R (FL5) Driver's Seat Cushion Frame Stop Sale (TSB Service Bulletin 23-030) IMG_8480
tuhroo
tuhroo
CTRifecta
MA
JHMFL5G40PX001110
Impacted?
Thanks in advance!
scoutduke
Oxford, Alabama
Yes, 128. Hope this helps.
Okay thanks. So yours hasn’t been repaired I assume. It’s a littl hard to tell from the picture angle, but I don’t see an inner fillet weld. It looks like just haz From the weld on the outer side of the seat. Hopefully I can get one or two more pictures from others 630 and under w/o repair. I’m just curious as to what the difference is between bad frames and good frames. Also thinking that the passenger side is going to need repaired as well, but we’ll see.
@tuhroo Apologies if I missed this in the thread somewhere, but do you have any more details you can share on the stop sale? Is it exactly as it sounds, no more sales of this vehicle until the seat fix is sorted out?
daazn
97 Miata
I believe the stop sale only applies to certain VINs.
Rad Ray
Ray
Mine hasn’t been repaired. I tried to capture in one photo the cross bar weld as well as the anchor bolt. Judging from previous posts (descriptive, audio, and/or video), it seems the squeaking most often occurs during lateral (side-to-side) changes in load. If so, the cross bar’s tension should not shear as much as it would during a vertical shift. I have no evidence, but suspect the squeaks originate from binding in the upper frame rails. I would be most concerned if the anchor bolts were faulty. Time will tell. I just hope that those recalled get it done quickly and without further complications.
