Road departure and collision braking mitigation problems
Biscuitpie
DFW
2000 S2000, 2018 340i
So, I just got my car delivered the other day and had these errors present from the very first time I drove it. I've tried resetting the battery and don't see any codes on my crappy scanner. What's weird is that I can sometimes get it to work by opening the Honda sense menu before the engine is turned on, so it must be a software issue. I'm gonna go to the dealer tomorrow but wanted to see if anyone else has experienced this so that I can help them fix it more quickly. Or maybe there's some simple fix I can do myself? Thanks in advance
11th Gen Honda Civic Road departure and collision braking mitigation problems 67839E7F-F727-416D-92D2-272CBC68678B
11th Gen Honda Civic Road departure and collision braking mitigation problems 32534CC1-D646-4901-9DDF-8060FFA97827
CTR
Only other thing you could do is check that the windshield/rear window is clean where the cameras are.
Biscuitpie
DFW
I already gave the car a full detail, so unfortunately it's not that
Biscuitpie
DFW
Went to the dealer and they reset everything. It worked for a bit but came back next time I started the car. I'll keep updating this thread in case it happens to someone else.
Noize
Under the radar
I had this a few times in a row, but it turned out to be my radar detector placement. I moved it, and no issues since.
Biscuitpie
DFW
So I actually just got this fixed. The dealer ordered a new front camera module and all is well now.
Biscuitpie
DFW
So weird, it's not like this is a unique part for the Type R. Mine is still fine a couple hundred miles later thankfully
2013 Civic Si Sedan, 2018 Civic Type R
Just went through this same issue and my dealer couldn't find any codes. My dealer ordered a new camera module as well, hopefully it resolves the issue. My car has 137 miles on it.
Biscuitpie
DFW
Hope so man, mine still has 0 issues 1600 miles later
007
2023 GR Yaris - Circuit Pack
I would pay big money to have lane assistance, pre-collision, auto start-stop, rev-match, and other assists permanently disabled. It's the most annoying problem with modern cars.
Noize
Under the radar
If I wash my car, or it rains, I can pretty much guarantee it will do it whenever I start to back out of the garage if the car is still damp. Sometimes it doesn’t even need to be wet, it just decides it’s going to do it that day. And sometimes it doesn’t do it for a couple of weeks.
But I feel a little trapped, because I don’t really want the dealer messing with my car. Like I’d probably rather put up with it than risk them mess something up.
It always corrects itself within 10 seconds of driving, and sometimes reboots the head unit whenever it does it.
007
All of these things can be turned off in the CTR.
Really? Are you sure *all* can be turned off permanently and not have to be turned off each time you start the car?
