juslearn112
jeff
bay area
2025 fl5
Hey guys, I need some advice. I just bought these coilovers for Black Friday, and this will be my first time installing something like this. Do I need any specific tools as a strut spreader? Thanks.
B16B
2025 Honda Civic Type R
MrBBQ
Danny
SoCal
I lowered 2 FL5's last month (my 2024 and a 1 month old 2025) on Swift springs. Use lots and lots of WD40 to get in between the strut and knuckle. Wiggle the two pieces, spray some more. We were able to get slide the knuckle down with minimal effort. The hardest part was the last few mm needed to slide the the knuckle off the bottom of the strut, which a large pry bar is needed. Recommend taking off the Axle nuts too, it's not that hard, and push the axle inwards to avoid the chance of it popping out of the transmission.
juslearn112
jeff
bay area
2025 fl5
Man, I wish I had seen your message before starting. I ended up getting so frustrated with the knuckle that I just yanked it off, and I popped off the axle. Thankfully, there was no fluid or anything, and I ended up being able to reconnect the axle to a transmission. Hopefully, it won’t leak? I spent a day just to do one coil.
B16B
Man, I bought something similar, and I’m still struggling to take off the knuckle. Any suggestions?
That tool, plus some PB Blaster type of lube, dead blow hammer, decent size pry bar, loosen the axle nut, and patience. When you insert that tool in and spread the knuckle open leave it in there until you see some progress.
juslearn112
jeff
bay area
2025 fl5
Thanks. I’m going to head to the store tomorrow to buy everything. I didn’t know to loosen the axle nut for the one I got done.
B16B
They say to do the one on the driver side because of the seal, but I did both sides just to relief pressure when lowering down the knuckle assembly.
juslearn112
jeff
bay area
2025 fl5
Man, I wish I got this information before I started because I popped it right off, but after putting the axle back on, I didn’t see any fluid. I hope it will be okay. Lol
B16B
Hopefully you'll be fine, but I think most report the leak after driving, but I could be wrong.
Jack90210
Central VA, USA
2025 Type R
A few pages back someone indicated that a spacer was helpful to dial in the height. Can someone clarify why this might be needed?
juslearn112
jeff
bay area
2025 fl5
Hey, I just finished installing the coils over Christmas holiday. What spacer are they referring to? I don’t think I used it.
B16B
What spacer and which post are you referring to?
