RSR Best-I Coilovers; need anything else?
TchnoZ33
Zaid
Indiana
Hello,
I am strongly considering pulling the trigger on RSR best-I coilovers. I just wanted to know if I need to purchase anything else in addition to them?
I have a RV6 sway bar with Honda accord end links that has not been installed yet; would I need to get a different set of end links?
Thanks!
furyousgeorge
2025 FL5 Type R
I’m about to install, and we need the bump steer correction kit and an anti lift kit with stiffer front wishbone rear bushings to give more caster adjustment.
Apparently Spoon sells a bump steer correction kit and PowerFlex sells the anti lift kit.
plus if you want more camber adjustment you should get the RSR adjustable top hats.
TchnoZ33
Zaid
Indiana
By any chance can you link me to these? I wish the coil overs just came with parts that would correct for the changes in ride height.
MERAKIAUTOWORKS
Joshua
Fullerton, CA
2022 Civic Type R
We sell them a lot with SPC rear arms and whiteline front joints.
Let us know if we can help. RSRs are out of stock though
-Josh
TchnoZ33
Zaid
Indiana
Honestly, it’s a bit overwhelming. I want to make the car handle better. I have no idea what parts are absolutely needed when trying to put on a coil over kit. I don’t plan on running a lot of camber. What parts would def be needed to make it run better without going crazy.
MERAKIAUTOWORKS
Joshua
Fullerton, CA
2022 Civic Type R
What I mentioned above, don't need the front or the rear, helps with dialing in the fitment.
-Josh
