Si Brake Pad Size
sackofcheese
Andrew
Central KY
Has anyone been able to find if the new Si caliper is a shared one with another Honda/Acura product? I need some heavier duty pads for my Si, but gotta keep the stock calipers for autocross classing. It would be nice to see if anything other than the stock pad already exists.
fastSI
Trois-Rivieres,Quebec,Canada
Civic Type-R 2018 CW #13019,SI 2022 RR
I work in parts for Honda and the SI 2022 runs the same brake pads in the front as the Accord 18+ (Sport,2.0 Sport and Touring models) so you can look it up on the web OEM PART # 45022-TVC-A51 if they might have a conversion #
As for the rear they have theyre own brake pads .. OEM PART # 43022-T38-A01
alhounos
Oregon
I just got a set of Carbotech 1521. Somebody on another forum helped them get set up for the new Si, so you should have access to any of their pads now.
sackofcheese
sackofcheese
Andrew
Central KY
Is this the same part number as the EX-L Pad size or is it different?
zeroptzero
Joey
Ontario Canada
That is cool, I really like the 1521 compounds, so glad to hear they are available.
alhounos
Oregon
Well, absolutely destroyed the stock pads after just a couple track laps, so I ordered a set of XP10 front/ XP8 rear per Carbotech's recommendation.
Yikes, $1000 on brake pads in just a couple weeks. Should have street and track use covered for a a good while now though. Motul 600 fluid going in soon as well.
alhounos
Oregon
Yeah, that doesn't look normal...
11th Gen Honda Civic Si Brake Pad Size IMG_0129
