- Joined
- Apr 24, 2018
- Threads
- 41
- Messages
- 539
- Reaction score
- 670
- Location
- USA
- Website
- twostepperformance.com
- Vehicle(s)
- 2023 Type R
- Thread starter
- #1
SPEC Clutch Proprietary Clutch + Single Mass Flywheel Combos for the 2016+ Honda Civic are now available to order! These are expected to start shipping in about one week. With torque capacities from 342 to a whopping 659 ft lbs, we have an option for everyone!
Check them out here: https://twostepperformance.com/search.php?search_query=spec proprietary§ion=product
These clutch kits use SPEC's proprietary design and must be paired with one of their flywheels. The result is a clutch kit that comfortably holds large amounts of torque, both on the track and the street. We have been testing the Stage 3+ setup, rated for 553 ft lbs and have found it to be very street friendly! (More so than the FX350 we previously had experience with)
All current options are paired with SPEC's aluminum flywheel, which weighs in at 11.2lbs, just under 20lbs lighter than the factory dual mass flywheel! A bit of added drivetrain noise is present at low RPMS under low loads after shaving this much weigh off the flywheel. If you are particular sensitive to noises such as this, you may want to wait for the soon to be available steel option. The steel flywheel will be a bit heavier, sacrificing a small amount of performance for the reduction/elimination of drivetrain noise.
No check engine lights or "misfire detection system" errors were encountered with this lightweight combo.
We believe these kits are what the tenth gen Civic community has been looking for, and we are proud to offer them!
