Stage 1 Tune
Shinjari
Richard
San Diego
'17 WOP Civic HB Sport 6MT, '03 Honda CBR600RR
@Two Step Performance is this useable on non-SI models such as a Hatchback Sport? Or do you have something in the works for non-SI platforms as well?
CrippleRipple
Kansas
2018 Honda Civic Si (LSM)*SOLD* & 2018 Honda Accord Sport 2.0T (CBP)
Nice! Man, no wonder the 19/23 starter map falls on it's face on the top end! Good numbers!
This looks very nice for the price! Pretty curious about this.
Been seeing a lot of E-Tune's in the $300-400 range.....which is what a shop usually charges for an in person tune and a few dyno pulls. Not sure I understand that. Good option for those in the middle.
I like being able to dial in my preferred quick adjustments but that's a nice gain on the stock maps and it seems to have most of adjustments I use.
Does the map lock up like Vit's maps?
Jntsunami
Jeremy
Olympia WA
2017 Civic SI Sedan
I just purchased the Stage 1 from TSP and flashed my ECU. I don't see any difference from the Dual Starter 19/23 PSI that comes from Ktuner...
Hijinx
Montgomery, AL
2014 Fiesta ST, 2016 Civic LX
Did you swap maps? 30wtq should be noticeable.
Jntsunami
Jeremy
Olympia WA
2017 Civic SI Sedan
Just add these to it... Early Spool, Disable Rev Hang. Standard padding, Aggressive Ramp II, Improved Throttle Response II. Basic 2 Step 4000/4000.
Jntsunami
Jeremy
Olympia WA
2017 Civic SI Sedan
I switched between all 3 maps that are loaded. Just saying can't tell much of a difference besides the smell of the clutch lol.
Jntsunami
Jeremy
Olympia WA
2017 Civic SI Sedan
You will definitely notice a difference from the KTuner starter base map left how it is but if you tweak it a bit you can just about get same results.
Jntsunami
Jeremy
Olympia WA
2017 Civic SI Sedan
You can't tweak any of the setting in the TSP Maps FYI...
ParkwayDrive13
Quentin
KS
10th Gen Ralley Red SI
You won't get the same results out of the ktuner basemap & this tune by modifying the quick adjustments.
The power is made from the increase in boost, and the ingition timing & a few other tuning adjustments. But nothing that can be done in the quick adjustments if that's what you meant.
