Stock exhaust: is there enough space to fit 3 4.5" tips
NorCal
EG6, S2K, Suburban, CB650R
https://www.amazon.com/gp/product/B0B87S8X96/ref=ewc_pr_img_1?smid=A3TYDC3FZVR30L
I've done a good amount of searching and have been looking for 4.5" single wall flat cut tips but double wall is all I could find. I'm looking to have the stock tips simply be cut off and these welded straight with no issues.
The problem could be that the > | | | triple pipe on the awe muffler is spaced perfectly for the 3 4.5" tips vs the stock muffler could be this > ||| and the 3 4.5" tips wont fit/crammed
Also looking to see FL5 on konig hypergrams
gerryman81
Austin, TX
2024 Civic Type R Sonic Grey Pearl
I have these double wall tips from amazon installed on my stock exhaust. I did this at the same time as my dual resonator delete and the shop was able to weld them on. Check my post on the rez delete for pics and a couple of my thoughts on it
Another Motorist
NorCal
It looks like you did the 4" units and someone near end of thread did the 4.5"
gerryman81
Austin, TX
you are right, looks like I did the 4" tips. I think there would still be enough space to do 4.5" tips but it might be tight. Just make sure you are using a good shop that knows what they are doing since they had to build a coupler to adapt the tips to the exhaust and make sure everything looks even.
Another Motorist
NorCal
Hopefully, shall see eventually lol. Going with dual res delete + tips on the stock exhaust. I'm surprised the k20c1 doesn't make much power through the exhaust so likely going this route.
AspecR
Stefan
I wonder how a 4.5" tip for the Center and 4" on either side would work
Another Motorist
NorCal
still oOo haha maybe filled in a bit more. It'll definitely be eaiser to fit than 3 4.5"s
Another Motorist
NorCal
