zumbooruk
- Joined
- Oct 19, 2024
- Threads
- 12
- Messages
- 707
- Reaction score
- 674
- Location
- Ventura CA
- Vehicle(s)
- 2025 FL5, 2014 Chevy Suburban (wife), previous 2007 FA5
- Thread starter
- #1
My FL5 is the first car I ever modded
Obviously, I have very little experience modding, for example, I just learned about the importance of unsprung weight...
I do not plan to race or track, but I do drive "enthusiastically".
I'd be the first to admit that I am not a very good driver, I drive like an ape, not smooth, no finesse, but I am having a blast driving my FL5
I have done all the work myself and I really enjoy and proud of it, especially since I am a software guy and this is hardware, which I always found "challenging"
So far I have installed PRL rear motor mount (but considering the Cobb RMM), initially a DE5 and now DSC suspension controller, Cobb intake, Cobb AccessPort (with custom tune by @JST Performance), PRL coolant expansion tank, WOT/HPT cooling tray, Hybrid Racing short throw shifter and cable bushings (still in the "to be installed" box: Radium dual catch cans, 27Won Snorkel, 41.22 kill switch with the optional remote)
I am extremely happy with the noticeable increased performance of the Cobb intake and @JST Performance tune, not looking for more power for now, so I am shifting my attention to suspension, which I know nothing about, seeking advice
These are the mods I am contemplating, in no particular order:
lightweight LiFePO4 battery for 30lb savings at the front (when OEM battery dies, or sooner)
MITA FKS wheels in 18x9.5 +60 (I don't want to mess with OEM geometry) with Continental ExtremeContact Sport 02 265/35R18 (I want a bit more sidewall) for about 11lb saving per corner or about 45lb total, though I am also considering 275/35R18 for even bit more sidewall. (when the OEM tires wear out in another 9-10k miles)
RV6 Swaybar and endlinks
Powerflex wishbone front anti lift and rear bushing
Wunderladen upper motor mounts, transmission side and the just announced passenger side
Spoon stiff plate (or similar bracing)
Rigid collars
Mugen performance dampers
EBC Yellowstuff DP41210R DP42402R (when OEM pads wear out)
anything else I should be considering? I do not want to lower the car, as is I scrape the front every time I go down my steep driveway.
anything above that I should not be considering, or a better option?
what about optimal alignment? keep at OEM? if not, what would you recommend?
Rigid collars
