Sway bars
Drozboyz
Woodstock ga
2024 fl5
Hey group Moving on to next mods fl5 Latest recommendations for front and rear sway bars? TIA
I installed the RV6 RSB. Not sure what options are out there for the front.
Drozboyz
Woodstock ga
2024 fl5
What setting did you use thanks
I'm using the middle setting. The car rides stiffer but I did Eibach ProKit springs and the RSB at the same time.
Thanks for the info. Why would you not add a front sway bar
1.) The OEM front sway bar does great for the car as is
2.) You have to drop the subframe to change it out. :S
Drozboyz
Woodstock ga
2024 fl5
My apologies…. Newbie here So there is a front sway bar underneath? What about strut bar on top? Any suggestions? Needed?
Yes there is an existing front sway bar under the car. There is no strut bar from the factory. The benefits of adding one are debatable but many choose to do so because they are somewhat inexpensive (compared to other mods) and easy to install. My favorite is this all welded design from 27WON that also includes a brake brace. I would say the brake brace makes more of a difference than the strut bar itself.
https://www.twostepperformance.com/...-front-strut-tower-bar?variant=40307056967812
svvitch
I have the RV6 bar with their end links. Set to middle setting around 900 lbs.
Anyone else getting some noise from the end links? I double checked yesterday everything right still have some small clunks over low speed bumps. Just curious.
WOPSiWOT
South Carolina
2024 Civic Type R | 2017 Civic Si Sedan (sold)
All metal bushings are going to make noise. That’s the trade off for the performance. Keeping them lubed will help some, but clunking is normal. That is the endlink bushings. I guess make sure the bar itself isn’t contacting anything, but that would be more than a little clunking.
