Icehawk
Icehawk
2023 CTR #3177 (stolen)
Edit: 1 more question: did you lower your car or is the smaller wheel gap from the larger 265/40R18 tires?
Thank you!
The tire is about 1.1" taller so the gap will be closed by half that, it visually will appear like a .55" drop while actually raising the car's height by that much. I found that double "benefit" to be useful on my last Miata that didn't have fully adjustable suspension height, looks better and gave better clearance over low stuff.
Finally got one of my titanium knobs installed "correctly" and moved the OEM one over to my wife's Si. Same style as OEM but about .5"cm or so shorter. I'd still love to get a red collar in there without it being wonky or costing me a 2nd boot but I'll deal with it after I get my other shift knob working in the car - I need a quick lathe job and the first couple places I tried were a no-go.
11th Gen Honda Civic What did you do to your FL5 today? IMG_3841
Thank you sir!
You're welcome. It may be helpful to level set expectations. The part titled, "Center Console Carbon Fiber" is a bit of a misnomer as it's NOT a center console, it's a center console overlay. That's an important distinction to make because nowhere in the product description does it state that. The same is true for the part titled, "Carbon Fiber Interior Door Panel". These are not replacement door panel pieces, they are overlays. See the below photos.
11th Gen Honda Civic What did you do to your FL5 today? IMG-20230503-WA0001
11th Gen Honda Civic What did you do to your FL5 today? 20230603_094500
Jcruz87
Tri state
Thank you for the heads up!
s2kdriver80
Paul
I installed the interior CF package in the FK8, and if the official install procedures are similar for the FL5 (mask off, alcohol wipe, adhesive promoter wipe, stick on, and lastly remove masking tape), then I recommend removing the masking tape before sticking on the CF overlay, so you can better see where you're placing the piece, relative to the surrounding areas. The masking tape is only to prevent the promoter from getting on those surrounding areas.
Jcruz87
Tri state
I would imagine that it wouldn't be extremely difficult for a company to make a full replacement piece.
Not sure what you'd gain from that other than a negligible amount more material and tabs that are susceptible to breaking. Once installed, if you didn't know it was an overlay you'd be none the wiser. It sits completely flush and you cannot see any of the faux aluminum console anywhere.
MrB
UK
I'm so close to pulling the trigger on the carbon pack...
I've heard that term a few times in the UK thread. What exactly is the carbon pack and what is the cost?
Village911
SoCal
FL5 #839
MrB
UK
It's the carbon wing, centre console and sill plates, I think it's just over ÂŁ3,000.
Very helpful, thanks. The carbon fiber accents are a winner IMHO. It elevates the interior and gives it a special feel.
