RUNN1N
I installed the LASFIT bulbs (turn signals, reverse lights, and trunk LED) and the whole process took me 12 minutes from start to finish--this is by far the easiest upgrade I've done yet.
This video was really helpful:
For anyone planning to take this on, a few pointers:
  • There's no need to remove the battery when performing this work--start with the trunk light so you can remove the halogen bulb while it's cool.
  • The reverse lights and turn signals are directional--test to make sure each one works before buttoning everything up. For reverse lights, put the car in accessory mode and shift to reverse. For turn signals, hit lock/unlock on your keyfob.
  • There isn't an audible "click" when you get these bulbs fully seated, however, it's easy to feel once they're fully in as they become snug and there's no wiggle/play.
Also, LASFIT now offers these bulbs as a package for $80.97, there's an additional 10% off your first order + free shipping, so the total comes to ~$73: https://www.lasfit.com/products/honda-civic-2022-2023-combo-package-upgrades?variant=43908960059639
[Js]
Jon
Milwaukee
2024 Honda Type R
Will absolutely do that - have an install date this Tuesday.
Here they are without the center caps - they look pretty good. I’ll take some better shots with the center caps in when there finished.
Now to get rid of the fender gap.
Dyno dates set for the 29th !
11th Gen Honda Civic What did you do to your FL5 today? IMG_1875
11th Gen Honda Civic What did you do to your FL5 today? IMG_1876
[Js]
Jon
Milwaukee
2024 Honda Type R
Pulled up to the house and these things finally arrived - install was seamless
11th Gen Honda Civic What did you do to your FL5 today? IMG_1878
menikmati
STI, BRZ, FL5
I got this combo and have an issue with the turn signals.
I had my hazards on and was using the front turn signals in the side mirrors as a reference. After about ~2 minutes of having my hazards on, the LEDs went from a 50/50 on/off duty cycle to more like a 25/75, so it would have a longer duration of being off than being on. Then the rear turn signals would de-sync from left-to-right, as in each side was blinking independently of one another.
Swapped in the original turn signal bulbs and put in a support ticket with LASFIT.
EDIT: Went on the site for the T-7440A bulbs and it appears that they will hyper flash when they get hot:
"2. Since these bulbs built-in Intelligent Temperature Control, if you use for a long time (a few vehicles maybe 2-5 minutes, it depends on year/make/model and temperature) may happen hyper flash, please turn off and cool 1-2 minutes, they will work properly again."
This has been mentioned in reviews on the product page so I will stick with the stock turn signals due to this.
s2kdriver80
Paul
I've probably gone 10-15 minutes with the hazards on using the typerled bulbs in the FK8 and didn't have an issue.
