Lay down some PPF. They sell precut kits or DIY
Doesnt the ppf adhesive cause damage to the screen? My understanding is that it can potentially rip off the pre-existing anti glare. Same reason why when you remove ppf on the outside of the car, you need to recondition the clear
SKINNIE
DFW TX
ISF, 23' BB FL5
I have no idea lol. I usually just blow off the dust and lightly wipe the cluster screen with a microfiber towel.
Montrix
Andre
Massachusetts
2025 Type R SGP
I'm guessing the gauge cluster doesn't have an anti glare coating on it, though I could be wrong. This is currently the plan though, I'm likely going to order a new lens, get it PPF'd and then I'll swap it out.
It seems pretty reflective to me, plus it's just plastic afaik.
CafeApex
AZ
2025 BB FL5
Noticed my Acuity shifter was feeling way off and was making a lot of noise. Turned out the base bushings had come loose and was causing the entire assembly to move slightly each shift. Started from scratch and reseated the bushings. With as smooth as the shifter feels now, I can concur that it hasn’t been right from the beginning. Now I get the hype!
11th Gen Honda Civic What did you do to your FL5 today? IMG_8145
iTurn
Cayman Islands
Serviced her, finally swapping from the OEM trans fluid to MT-90 and installing the Acuity transmission bushings. I've had both the fluid and bushings close to a year now but laziness. Didn't think it would be a big improvement because car is under 13k miles, but both made a huge difference in the smoothness of shifts.
11th Gen Honda Civic What did you do to your FL5 today? WhatsApp Image 2026-09-16 at 5.10.02 PM
MTN
Bay Area
26 Type R, 25 Audi RS3, 19 Golf R, 16 Porsche Boxster Spyder, 12 Audi TT RS
Got the car detailed, just waiting for my Mugen lip to come in so I can finish it.
Where did you get the alcantara trim for the dash vent? Looking good
Wogboy
Howard Ino
Sydney, 'Straya
2023 FL5 Type R
coming up to 3rd anniversary with car
so thought i would spoil her with a nice wheel clean
easiest way to clean em??? jack the vehicle up and take one wheel off at a time
took just over an hr in total to do wheels and calipers
used cheap wheel cleaner on calipers and one of the wheels which had baked on dust and crap
other 3 wheels i used hot tap water mixed with cheap truck wash and then gave em a wipe with some spray
just way easier taking the wheel off and cleaning it then on the vehicle
piece of piss :p
11th Gen Honda Civic What did you do to your FL5 today? cb485578-fa49-4723-9757-6b6ca8572c57
11th Gen Honda Civic What did you do to your FL5 today? b7356957-e003-4860-a7b7-cd7af88f3ea7
11th Gen Honda Civic What did you do to your FL5 today? c97c8c3a-1cf1-44ca-a1e4-de578b4ca287
11th Gen Honda Civic What did you do to your FL5 today? 3ea48443-df6b-4d03-8f67-87b55e6d92a6
11th Gen Honda Civic What did you do to your FL5 today? 81e551d8-640d-4bbb-bfef-92e337913738
11th Gen Honda Civic What did you do to your FL5 today? 3252499b-b9d0-40b6-8ff9-c5b588814aa5
Unity Performance
Humza
Toronto, ON | Buffalo, NY
unity-performance.com
Does the XDi uprated fuel line work with the Full Race HPFP? I've seen on this forum where some say it works others say it doesn't, so I'm unsure. If it does work it would make waiting for a viable solution alot easier.
Most of the installs are complete, and we're a little sure about the line so I've emailed XDI the following:
1) Are both ends the same on the line? Visually it's hard to tell them apart
2) Is this line rated for ethanol use?
3) We're barely getting 3 threads of engagement with the fuel rail, is this normal? Tried both sides.
Either end threads into the Full-Race HPFP just fine.
Will post what we get back from them. Everything else has been smooth sailing thus far *fingers crossed*
Is the XDI upgrade fuel like made by 4piston?
Nothing done to the car itself, but I got a new key fob cover made of Alcantara. Saw one on Amazon, but they wanted over $40 for it. Found it on AliExpress. I don't usually buy stuff from sites like that or Temu, but for less than $20 I decided to give it a try. It sort of matches the Orbitkey organizer I have with the red stitching.
https://www.aliexpress.us/item/3256806270593111.html
11th Gen Honda Civic What did you do to your FL5 today? 1789760569244-yd
11th Gen Honda Civic What did you do to your FL5 today? 1789760580935-d5
Surprisingly I got a couple messages about alternatives to the Razo shift knob, so here are couple suggestions:
Happy Racer Development CYL shift knob(350+ grams) available in 2 colors
11th Gen Honda Civic What did you do to your FL5 today? 1789764149759-uu
DC Sports Shaft weighted knob(402 grams), available in 3 colors
11th Gen Honda Civic What did you do to your FL5 today? 1789764241964-xl
Billetworkz Hybrid shift knob, comes in delrin so your hand doesn't burn.
11th Gen Honda Civic What did you do to your FL5 today? 1789764547281-a8
Do the buttons still have a click? I ordered one off Amazon a while back and I barely felt the buttons when I pressed them
Yes, the material is a little stiff, but mine still clicks.
