rui
NY & PT
EG6, AP1, FL5, FE1
Looks like insulation to prevent intake air from being warmed up by the hot air around the turbocharger and exiting from the hood vent.
metal_driver
Ottawa
2004 TSX (Euro-R mods), 2009 Acura TSX, 2008 MDX, 2011 Shelby GT500, 2018 Type R, 2020 MDX A-Spec
Looks like the spot to put your ice pack in when frozen - lol
Vincent@27WON
Vincent@27WON
REDEFINE the Aftermarket
Vincent
Las Vegas, NV
www.27won.com
Lust
Michael
Bay Area
2019 Champ White Type R
A compartment for my hotpocket or dry ice. Nice.
TypeSiR
Car Driver
On a Twisty Road
1.5T Civic, CTR, MX-5, Fit
Joe Raiti will need to tell us how many hot pockets can fit in there when he does the full review.
JR: It has enough room to fit several of your favorite strawberry hot pockets so you can wash it down with your big-gulp Diet Coke. I’m gonna have to zonk the back seat leg room. I’m 6-ft tall. As I’m seated at the back, it has too much leg room. You can put a dining table in there. So much waste….
Toprarnen
IS350
Do you guys think it could be an aesthetically-pleasing intake cover of some sort to keep debris out, due to the new location of the hood scoop?
sgtmorph
Long Island, New York
OMG 🤣🤣
100%
I can hear his voice while reading that…I’m dead 🤣🤣🤣
someone needs to tag him in this lmao
Vito.FL5
Victor
Brazil
its a resonator chamber. For sound purposes.
S2000_Europe
Type R
any update in this? Regarding the air vent on the hood, there is an air diverter below it that points to the DP, same as my Renault 19 Sport in the 90's but the air was diverter to engine.
Fl5R-23272
Enzo
New jersey
Civic type r
There has to be a serviceable part within that box, they would not use those bolts for a decorative plate. They could have used rivets or adhesive if it was not meant to be opened, those bolts were meant to be opened and closed if needed for some reason. They are a pretty good sized bolt, so they will hold some decent torque, too much for something decorative. That plate will likely have a seal on it , hence the bolts being used to keep the seal tight. What it is I dunno, but it is an active serviceable part for sure.
There is no serviceable part inside.. it’s just a casted pipe with a cover plate.
11th Gen Honda Civic What's in the Box (Heat Sink)??? FL5 Turbo Inlet Pipe Uncovered. IMG_0470
evlsmurf
2016 Subaru Impreza Sport
Does that mean the plastic cover can be replaced with something else, like titanium? Or, would it be smart to keep the plastic to reduce temps?
Fl5R-23272
Enzo
New jersey
Civic type r
Prl and other company’s make milled aluminum finned plates to reduce heat radiating off the turbo. Since the turbo is literally right under the inlet piping it stores more heat naturally.
