Widest Tires on 18x9.5
TchnoZ33
Zaid
Indiana
What are the widest tires I can run on a stock height FL5 if I have 18x9.5 wheels? Can I run 275 35? Any issues with rubbing? If I decide to lower the car with those tires on, any issues? Thanks!
julianobl
?? Puerto Rico
2023 FL5 - Sonic Grey
what offset?
275 is as wide as i would go on a 9.5 rim
i think you’ll be fine I run 18x9.5 +45 on 275/35s without any issue
TchnoZ33
Zaid
Indiana
Street and spirited driving. Probably gonna be all season pilot sport.
nattypiso
Dom
Fayetteville, NC
FL5 CW R-05536
Currently running Eibach’s FL5 specific Sportline-kit springs (1.2 inch drop on the front and .9 inch in the rear) along with TE37 SL’s 18x9.5 +45, perfect flush fitment, with 275/35 on Falken FK460’s. No rubbing at all, so you’ll definitely be fine at stock height.
Experience may vary depending on your spring/coilovers, how aggressively you drive, and tire choices. I’ve heard that depending on the tire manufacturer, some tire sizes aren’t what they say they are and can be slightly inaccurate. So stick with good brands or ask what people are running on their wheels.
Zero7
Avtar
UK
FK8
Any impact of running 275 on the street - does it tramline more, also in the same boat as OP. Getting CE28n's in 9.5 with a 38 offset
I run the same size CE28's with a 275/35/18 and have zero issues.
svvitch
Keep in mind those V730 run a little wide compared to PS4S or ECS
