Will any 6mm washer work for transmission check valve
Mawfuqqa
FL5 #9000!!
Title.
Or
- Drain it on ramps
- Lower back down on flat ground to maximize drain
- jack up to install drain plug
- fill 2.3qt and done.
ModJPB
Jason
Do you mean the upper fluid level check bolt?
For short term/temporary use, Yes.
For long term, No.
The washer has to be corrosion resistant to outside elements (oxidation) and cvt fluid, soft enough to deflect and seal, and a compatible metal with the aluminum trans housing and steel bolt (galvanic corrosion). I'm thinking an aluminum washer would work.
Why not reuse the original or go to the dealer?
Mawfuqqa
Mawfuqqa
FL5 #9000!!
I found it uses 9ftlb. I'll likely reuse it.
I have a bunch of 6mm washers of unknown metallurgy at work (likely aluminum)
I usually have no reason to go to the dealer
It needs to be an aluminum crush washer. I normally reuse the sight port washer, but I always replace the drain plug washer. There's no fluid pressure at the sight port, unless you park nose down in a very hilly neighborhood.
Mawfuqqa
Mawfuqqa
FL5 #9000!!
Definitely for crush washers
I'm going with redline mtl and a pack of crush washers for drain/fill
Will reuse check/sight port washer
