WOT Performance: HPT Cooling Plate
siwelnosaj
Jason
Reno, NV
Type R
Message me and I'll see what I can do
chopsuey34
West Michigan
Received my cooling plate yesterday, thanks WOT and Jason.
siwelnosaj
Jason
Reno, NV
Type R
The physical units are being built currently but here is the final design of the FL5 WOT spec triple pass radiator with transmission cooler! There is also an FK8 version in production and it will in essence be the same with different mounting points specific to the FK8.
PWR will also be releasing their own spec here soon. The WOT spec will have two primary differences:
1) More track oriented custom core spec: higher fin density, and special fin louver angle to further improve heat transfer.
2) Integrated bracket for optional transmission cooler: Built in provision on the back side of the radiator to easily add an optional transmission cooler to further reduce coolant temps by unburdening the coolant system (the OEM design uses the coolant system to cool trans fluid via the heat exchanger on the front of the transmission).
The placement on the backside of the radiator is to minimize interference with the radiator and maximize efficiency.
The idea WOT spec will be the ultimate level stock replacement radiator available.
This will fit just like the current PWR single pass radiator. No modifications needed, works with the fan and works with various intakes.
If you would like to order either spec contact me and I can set your order up. I will be the only vendor offering the WOT spec.
Price is $1600 without the transmission cooler attached (but can add it later since the bracket is on), $1800 with the transmission cooler, lines, and clamps. $120 for shipping, so $1720 or $1920 depending.
PWR spec will be $1400 plus $120 for shipping so $1520.
You have the option to plumb the transmission cooler in 2 ways: 1 is to integrate it with the OEM heat sink piece to maintain OEM warm up using coolant, or #2 is to completely bypass the OEM heat sink but at the cost of losing OEM warm up.
FK8 version will require the removal of the passenger side fan, but in talking with the PWR engineering team they feel confident this will cause no issues on the street and on the track it will actually help by removing resistance on the back side. I ran my FK8 daily and track for 2 years without the passenger side fan with zero issues even in 105+ temps in the Reno summer.
11th Gen Honda Civic WOT Performance: HPT Cooling Plate Screenshot_20250425_073900_Driv
11th Gen Honda Civic WOT Performance: HPT Cooling Plate Screenshot_20250425_073928_Driv
11th Gen Honda Civic WOT Performance: HPT Cooling Plate Screenshot_20250425_073958_Driv
11th Gen Honda Civic WOT Performance: HPT Cooling Plate Screenshot_20250425_074045_Driv
11th Gen Honda Civic WOT Performance: HPT Cooling Plate Screenshot_20250425_074018_Driv
siwelnosaj
Jason
Reno, NV
Type R
11th Gen Honda Civic WOT Performance: HPT Cooling Plate Apr-27-2025-Speed Ventures (Sun)-Red Group-Session 2 (Turn 2)-CPRP5092_Apr2725_839AM_CaliPhot
11th Gen Honda Civic WOT Performance: HPT Cooling Plate Apr-27-2025-Speed Ventures (Sun)-Red Group-Session 1 (Turn 3)-CPRP4150_Apr2725_705AM_CaliPhot
11th Gen Honda Civic WOT Performance: HPT Cooling Plate On Track Oil Temperature Comparison-1
11th Gen Honda Civic WOT Performance: HPT Cooling Plate On Track Coolant Temperature Comparison-1
11th Gen Honda Civic WOT Performance: HPT Cooling Plate FB_IMG_1745866505787
11th Gen Honda Civic WOT Performance: HPT Cooling Plate FB_IMG_1745866788162
Massive results during track testing yesterday!
Dual oil cooler set up is working and working well. Still need to make a couple of small adjustments on fitment and finalize brackets, but given yesterday's results with the prototype, it showed it's ready to perform. Hopefully I can get these adjustments made in the next few weeks and officially put the kit up for sale. Best part is you can't even see that there's oil coolers on the car, OEM+. I'll share pictures when it's ready for sale.
Testing was done in 2 parts. Saturday ran with no oil coolers, no cooling plate, OEM radiator. Sunday I added the oil coolers and later the cooling plate. Ambient temps were low at 62°, but this testing was about relative performance, 1 for 1. Oil temps were measured using a physical sensor added into the oil pan (post engine and pre oil coolers so it's at its hottest). Coolant was measured using the OEM sensor in the head.
On Saturday to create a baseline, the car was run in OEM cooling form (OEM radiator, OEM under tray, no oil coolers) I got the car to the limit with a peak oil temp of 290° and coolant up to 249°. This was in a session where I had my last 5 laps averaging 1:55.66 on the new Buttonwillow "The Circuit".
Sunday with the oil coolers added, peak temps dropped to 255° for oil and 219° for coolant. In this session I had the last 5 average 1:55.21. A giant 35° improvement in post engine oil temps, and 30° in coolant temps!
When the cooling plate was added, peak temps dropped again with oil at 249° and coolant down to 206°. Last 5 laps averaging 1:54.41. Another drop of 6° for oil, and 13° for coolant!
I experienced zero aero issues with the cooling plate added, I achieved my highest top speeds and highest lateral Gs with it on the car, 128.4 mph and 1.46 G respectively.
I will be returning to The Circuit in 2 weeks to run the WOT spec triple pass radiator and transmission cooler and I'm hopeful ambient temps will be in the 80s or 90s to show that the whole suite of cooling items collectively can get the job done in the heat!
Once I've finalized everything on the FL5 I will be working on releasing the kit for the DE5 and FK8. All 3 cars will have the same modifications available to them.
VtecSlayer
James
2025 Honda Civic TypeR
siwelnosaj
Jason
Reno, NV
Type R
11th Gen Honda Civic WOT Performance: HPT Cooling Plate FB_IMG_1747086129537
11th Gen Honda Civic WOT Performance: HPT Cooling Plate FB_IMG_1747086127303
11th Gen Honda Civic WOT Performance: HPT Cooling Plate FB_IMG_1747086124624
11th Gen Honda Civic WOT Performance: HPT Cooling Plate FB_IMG_1747086122194
11th Gen Honda Civic WOT Performance: HPT Cooling Plate FB_IMG_1747086120099
11th Gen Honda Civic WOT Performance: HPT Cooling Plate FB_IMG_1747086117656
Testing was a big success on Saturday for the FL5 WOT Spec PWR Triple Pass Radiator and transmission cooler! There is also an FK8 version available.
This was a true torture test with ambient temps getting up to 101°F by the last session.
Testing conditions were very different than 2 weeks ago when it was 62° out so it's impossible to create graphs and such to compare, this was more about performance in an absolute sense. Simply put, could the car run on track for full sessions at 100°F, and the answer to that was yes!
The quick summary is that I was able to run all 5 sessions on the day from start to finish without overheating and that I got a personal best of 1:53.5 in the early session when it was cooler out.
When it got to 100° I was only able to manage a 1:56.5, the tires, brakes, and intake temps just weren't as happy and the tires were at the end of their life with this being their 3rd track day and in the toughest conditions.
As I discuss the results it's important to keep in mind that none of the other Type Rs were able to match this pace. The next best time on the day from an R was a 2:02.98 done in the optional 10 minute time trial session and that was in a 2 hot lap scenario, he won his class. His car is mostly stock and his coolant temps hit 242° on the second hot lap with 92° ambient. The other Rs on the day were all around 2:08-2:13 for their best times in any session.
The most telling examples of the radiator's performance were the 4th and 5th sessions where it was 100° and 101° respectfully.
In the 4th session with 100° ambient I ran behind my buddy who is modded similarly but with the PWR track spec single pass. The plan was to run behind him so I could match his pace for multiple laps in a row and then we could compare temps in a more one for one scenario. We were running 2:08 lap times and at the end of the 4th hot lap his coolant was at 233° and was climbing, mine was steady at 219°. A massive 14° difference! I suspect if we did a few more laps the delta would have only continued to grow larger but he pulled off the track.
The 5th session was the real test though. Most everyone had left because it was just too hot out, so they made it a 40 minute open pit for whoever was willing. I filled up on gas and my plan was to run the whole session at an endurance race pace (around 2 flat give or take). There was a black flag right at the start of the session and so it effectively turned into a 30 minute session. I ran the whole 30 minutes in 101° ambient temp at an average pace of 2:01.9. Coolant temps remained stable at 228° - 233° for the 30 minutes. I could have continued but they waived the checkered flag. By the end of the 30 minutes I think I was the only car still on track.
So I was able to run slightly faster for 30 minutes continuously than the next fastest R did as a time trial effort all while keeping temps stable right around 230°. I was able to match coolant temps but keep them steady and go 7 seconds faster per lap for a mega session. Massive success considering the environment.
I am the only vendor selling the WOT Spec PWR Triple Pass Radiator. It goes for $1600, and $1800 with the optional transmission cooler added, plus shipping. If you're interested in one for yourself message me and I can set up your order. They are build to order with an approximate 4 week turn around shipping direct to you from PWR.
Direct bolt in, no modifications needed.
Message me if you have any questions or would like to set up an order.
Tougefl5
Banned
Banned
So happy you are out proving your stuff is working.
FL5CW
North America
Anyone from Canada get one? Nervous with tariffs, etc... Or any Canadian suppliers?
chopsuey34
West Michigan
