SpoolinFK8
Gogi
NY, NY
2024 Honda Civic Type R
I kinda want one but worried it 'sjust a novelty that'll wear off after a few weeks...still want one though
Nah you wont get tired of it. They have so may varieties of these Mochi
SpoolinFK8
Gogi
NY, NY
Alright guys, as promised resolved the issue with the Mic. ENJOY!! I know I am.
SP R KiD
Matthew
2023 BB CTR, 2021 Toyota Highlander, 2001 F150
Finally got the wheels on! Got some decent mid west weather and it’s looking optimistic going forward.
Apex wheels
Bridgestone Tires
P3 Paragon Pads all around
Castrol SRF racing Brake Fluid
RV6 Rear Sway Bar
Stickers the wife got me!
Stoked for the summer!
11th Gen Honda Civic What did you do to your FL5 today? IMG_4536
11th Gen Honda Civic What did you do to your FL5 today? IMG_4537
11th Gen Honda Civic What did you do to your FL5 today? IMG_4538
11th Gen Honda Civic What did you do to your FL5 today? IMG_4539
11th Gen Honda Civic What did you do to your FL5 today? IMG_4540
11th Gen Honda Civic What did you do to your FL5 today? IMG_4534
Finally got some springs installed, H&R which have the least drop possible and IMO is absolutely perfect. Also got camber ball joints installed in the front. Still need an alignment but went on a little drive to get things settled in. The awesome dudes that installed eye balled the toe and they got a good eye because the car drives perfect lol, I am sure its still off but feels fantastic.
Just waiting for alignment for some new wheels to go in
11th Gen Honda Civic What did you do to your FL5 today? IMG_1123
11th Gen Honda Civic What did you do to your FL5 today? IMG_1124
Thanks for sharing. You should have your ECU back from COBB by now. Interested to hear your thoughts on their OTS map.
I don't have it yet :-(
I have no idea why but UPS held it for an extra day at the local UPS facility, and only delivered on Wed (two days) instead of Tuesday
I wrongly assumed next day air shipping both ways. but COBB shipped it back via UPS ground. though they did ship it on Wednesday, the same they they received it.
and lastly I got notification from UPS that the ground shipment is delayed due to weather...
so I don't even have a delivery date
Today I installed the COBB intake in anticipation for the ECU
I got unlimited tune from @JST Performance in the bundle with the AccessPort and Jailbreak way back in November (but then my mother-in-law passed and I was very busy helping my wife)
I am new to this process, I am not sure if I'll even use the OTS map with the COBB intake
also, I'll be the first one to admit that I drive like an ape, and I am not a very attuned driver (pun intended).
TheFactor
Factor
So Cal
2025 CW Civic Type R
So i know most want to hear what the @PRL Motorsports PRL P700 turbo sounds like with the T51r mod. Here’s a quick cold start, and a few pulls (not sure what happened to my mic after but i’ll get better rolling videos and sounds)
Nice ! Sounds like a Jet plane 😆
BLU RRR
Jeff
South Central PA
PRL catch can and WOT hood struts installed. Easy installs on both for the most part. the PRL hoses are a bit smaller diameter than OEM and not as flexible so def use dishwashing soap, oil or windex to help put them on and dont get frustrated. There is little room to work but enough to get it done.
Anyone have a good solution to the OEM engine cover bolts? The heads are short and soft AF and I rounded one off trying to get it loose.
11th Gen Honda Civic What did you do to your FL5 today? IMG_4507
Wanted to try this carpeted well liner for the hatch from the FL4. I want to see if it helps cut down any road nose in the hatch and to also make it look more "finished", even though I know I don't open it up much or at all.
If you want to retain the foam insert with the patch kit and tools, you will need to shave down the high spots of the foam. I used an old chefs knife I did not care to mess up. Still sticks up a little bit but, it'll be hidden by the OEM all weather cargo tray. I might get a small tool bag that can fit everything and get rid of the foam later on, but it works for now.
P/N: 84528-T50-J51ZA
11th Gen Honda Civic What did you do to your FL5 today? 1774393811895-fx
11th Gen Honda Civic What did you do to your FL5 today? 1774393838506-q0
11th Gen Honda Civic What did you do to your FL5 today? 1774393850907-4g
