DmK
2025 FL5, Mx5 ND3
the larger MAF housing in the Cobb Redline does not force extra compression or raise temperature inside the stock inlet pipe
it reduces upstream pressure losses, and the velocity drops in the enlarged MAF section, which lowers frictional losses before the air reaches the turbo
the irreversible losses that would convert kinetic energy into heat are minimized by the velocity stack and straightener grid
although velocity does rise again in the factory diameter pipe, the overall result is higher absolute pressure at the compressor inlet than with the stock intake
Cobb has shared test data showing the airbox pressure stays closer to ambient which lets the turbo reach target boost with less wastegate duty, lower exhaust manifold pressure, and better efficiency
i.e. the intake flows more air with less restriction and helps the turbo work more easily rather than against added losses
in fluid dynamic terms, Bernoulli’s relation for steady flow shows that lower velocity in the large MAF section corresponds to higher static pressure there for the same mass flow
the smooth contraction that follows raises velocity and lowers static pressure, yet the total stagnation pressure delivered to the compressor remains higher because upstream losses have been reduced
for typical intake velocities the associated temperature changes are only a few degrees and do not meaningfully affect compressor inlet conditions
in short, the design improves turbo efficiency rather than creating additional work for it
https://www.cobbtuning.com/products...nda-civic-type-r-fl5-acura-integra-type-s-de5
Very detailed answer, thank you!
egxflash
CA
2024 Integra Type-S
Ironically, PRL's intake is now 50 state CARB legal in 50 states, but im glad to hear positive things about the Cobb, especially coming from Subarus.
I just realized I never got the CARB sticker from them that I submitted for like 1-2 mos ago!
MrBBQ
Danny
I realized I don't have a CARB sticker from COBB either. Will have to request one. 👍
SpoolinFK8
Gogi
NY, NY
2024 Honda Civic Type R FL5
My little guy every time he gets to rev the R. The pop is much louder in person than the phone makes it seem, you can see him jump on the second loud pop. Lol
Mrjustin81
Update: WAY WAY brighter than the OEM
Can finally use the mirrors instead of our low resolution back up cam
Got me giggling like the little guy too, that's awesome
SpoolinFK8
Gogi
NY, NY
Ordered some over night parts from Japan, I put it on my Tab at Harry’s. $218 on shipping & Tariffs fees.
11th Gen Honda Civic What did you do to your FL5 today? IMG_6521
11th Gen Honda Civic What did you do to your FL5 today? IMG_6520
SpoolinFK8
Gogi
NY, NY
I’ve been hoping to see someone try out those fuses and coils ever since I saw this vid a while back
I already have the HKS spark plugs installed. i also have the first version of the Japan High Spark coils.
Mrjustin81
35% ceramic all around and 70% on the windshield. Kinda wish I went a little darker but I’m getting old man night eyes , so for the best
11th Gen Honda Civic What did you do to your FL5 today? IMG_8070
SpoolinFK8
Gogi
NY, NY
I went with ceramic 50% all around and 70% on the windshield. Rolling straight out the dealer and straight to my friends shop lol.
11th Gen Honda Civic What did you do to your FL5 today? IMG_2332
Installed Ravelco Anti-Theft Device
https://www.ravelco.com
full discussion and details:
I had the Ravelco installed on Friday
The installer was awesome, loves what he does and it shows, answered all my questions, took his time and did a perfect job.
Works as advertised, I am fairly certain that it will be very difficult to defeat, video notwithstanding.
I still have the 41.22 kill switch with the remote control, new in box. I never installed it. not sure if I should sell it, or install it as a backup in case the Ravelco is defeated...
This should make drive-away theft very difficult, time consuming, if not impossible.
Next on my list is to evaluate GPS trackers for recovery when the thieves use a flatbed truck.
