MDR Intercooler fitting issues
LULU2873
LUIS
CONNECTICUT
2024 HONDA ACCORD SPORT HYBRID
I purchased a MDR intercooler and im
Having issues with the install
It’s keep hitting the impact bar
Has anyone had this problem?
Any help would be appreciated
Thanks
11th Gen Honda Civic MDR Intercooler fitting issues IMG_9830
11th Gen Honda Civic MDR Intercooler fitting issues IMG_9835
11th Gen Honda Civic MDR Intercooler fitting issues IMG_9831
11th Gen Honda Civic MDR Intercooler fitting issues IMG_9839
Deeyygoo
Diego
Fk8
Did you put back the rubber grummets back in the new intercooler? Did you remove rubber diverter flap both sides on bumper? From the pictures you posted it looks like something is not lining up, did the same intercooler on my fk8 and helped out my buddy with his FL5 and had no issues.
LULU2873
LULU2873
LUIS
CONNECTICUT
Yes I did
Yes the ones on the inside of the bumper
The new intercooler keeps hit the lower part of the impact bar
11th Gen Honda Civic MDR Intercooler fitting issues IMG_9845
LULU2873
LULU2873
LUIS
CONNECTICUT
Going to remove the under shield that should probably give me more room to put it in and to see if can do it on a lift that would definitely make life easier
Nikw91
Nik 772typr
WPB, FL
2025 CW FL5
You have to go straight back at the perfect angle. I had the same issue with the similar sized PRL intercooler. If the intercooler is tilted at all, then it won’t fit.
marcusm86
Marcus
Missouri
2025 Civic Type-R
I didnt have the "under shield" on when i put mine in, i had 0 issues - tilt the intercooler and fit in just fine.
I had this issue installing my PRL intercooler. It’s a very tight fit. I seem to remember having to use a lot of course language at high volume in order to get it in there.
The MDR intercooler is a beast. It's a tight fit for sure but I didn't have a lot of trouble with it. I'd say just keep fighting with it. :thumbsup:
