Coolant Temp Help
NewCivicRs
NewCivicRs
Indonesia
Civic 1.5 Turbo RS
Hello fellow friends,
Could you please advice regarding on ECT 2 increases gradually above 90 Celcius to 95, 96 and to 100 C and peak 102 C then drops sooner below 95 C and repeat the cycles as I kick down high boost on canyon uphill road.
Should I switch to 5W30 or stick to the Amsoil SS 0W20 or alter fan activation earlier on ktuner?
ModJPB
Jason
Are you asking because you're concerned something is wrong or you want to upgrade for better performance?
NewCivicRs
NewCivicRs
NewCivicRs
Indonesia
Civic 1.5 Turbo RS
Those temp fluctuations seem pretty normal, the thermostat opens and the temp goes down.
Do you recommend to switch to 5W30 or this is still fine with 0W20?
An oil weight change wont necessarily change your ect. You want your coolant to increase and decrease in temp since it means it's removing heat.
You should know what's normal by just driving normally and looking at your temps. Regardless 102C isn't outside the ordinary.
I recommend 5W-30 over 0W-20. It's okay per Honda UK owners manual too. 5W-30 provides a thicker oil film, without noticeable fuel economy changes. Or 0W-30 if you are often driving in sub-freezing weather.
I live in Southern AZ. I think my car got down to 35F one morning outside in Sedona, otherwise not below 50F in my garage. I use 5W-30 with no issues.
BTW many oils use synthetic base refined in Saudi Arabia, so don't get surprised by the recent price increases.
NewCivicRs
NewCivicRs
NewCivicRs
Indonesia
Civic 1.5 Turbo RS
I am asking if it is dangerous or not healthy for long term use in this case. Everything is fine. Actually I know it because I keep monitoring the ktuner V2, if I dont, I just drive it away as I wanted and everything feels normal. I just fear of suddenly blow it up. Either the CVT temp that reaches 115 C or engine scoring because high boost pull.
Should I switch to thicker oil or stick to the 0W20?
NewCivicRs
NewCivicRs
NewCivicRs
Indonesia
Civic 1.5 Turbo RS
Just stick to the 0W20?
NewCivicRs
NewCivicRs
NewCivicRs
Indonesia
Civic 1.5 Turbo RS
I see, but have you tried the 0W20 and any difference? Yours Type R right?
I think you're getting ahead of yourself. From your username I take it you have the civic RS, which is just a SI hatch with a CVT. You're also running a ktuner, which would imply a tune.
Generally speaking 5w-30 is good, but also we know nothing about your setup, tune, mods, etc. Could you please elaborate?
NewCivicRs
NewCivicRs
NewCivicRs
Indonesia
Civic 1.5 Turbo RS
Yes a hatch L15B7 CVT with TSP Stage 1 Non Si tune.
3 inch catless downpipe
3 inch frontpipe
HKS exhaust
Intercooler upgrade
93 octane.
No track purpose, only spirited driving + normal driving around city with tropical and humid ambient 32C.
Since car brand new until now I am using Amsoil SS 0W20 but now I am concerned about it although everything is normal.
CG13
Houston
2024 FL5 Civic Type R
These oil questions never seem to go anywhere. Use what Honda recommends. 0W20 or 5W30 and watch your temps, change with the right frequency, and you’ll be fine.
NewCivicRs
NewCivicRs
NewCivicRs
Indonesia
Civic 1.5 Turbo RS
Did you mean oil temp? If yes, unfortunately I can't monitor it. On my Ktuner V2 only ECT available.
Yes I wonder, should I go with 0w20 or 5w30?
